Led Flicker
Old Mar 7, 2010 | 09:53 AM
gpmarsha's Avatar
gpmarsha
Default Led Flicker
Replaced my interior lights with LED's and love the look. After several month's the left map light now flickers when the light is on. I did replace the light and for a while it worked fine then it started again. Anyone have any ideas what might be the causing this to happen?
Old Mar 7, 2010 | 10:03 AM
Tom_Slick's Avatar
Tom_Slick
Either a bad / faulty connection or a bad bulb? Not all bulbs are created equally... I'd suggest swapping out/ replacing with a different brand.
Old Mar 7, 2010 | 10:10 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Originally Posted by LS3 MN6
Did you buy high quality SMD LED's? If not get some from a Forum Vendor.
We have the high quality version ready to ship.
http://www.shop.jwmotoring.com/produ...1&categoryId=6
I highly doubt you have ours installed as ours never flicker, but if you do we cover them under warranty for 1 year.
Old Mar 7, 2010 | 10:11 AM
JW Motorsports
Banned Scam/Spammer
Exactly why we only offer 1 high quality version instead of the less quality "discount" version.
Old Mar 7, 2010 | 10:26 AM
gpmarsha's Avatar
gpmarsha
I just placed a order. Thanks again
Old Mar 7, 2010 | 11:09 AM
JW Motorsports
Banned Scam/Spammer
Thanks! They'll be shipped tomorrow.
Old Mar 7, 2010 | 11:36 AM
Glen220's Avatar
Glen220
Default Same problem....
I had the exact same problem. I bought the inexpensive bulbs from a (former?) forum member and after a few months they started to flicker. After research found that if you do not get the "high quality" ones, that is a common problem. The vendor I bought them from was not any help.
I have heard no complaints with the high quality ones.
Old May 14, 2010 | 02:07 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
I got some 194 SMD LEDs off ebay; six to be specific. The ones in the map lights and footwells are fine but the ones for the license plate flicker badly. I guess I'll swap them out with the footwell ones just to see if it follows the LED/bulb but I think it has more to do with the voltage that the the license plate bulb housings see. If all else fails I'll get a pair from JW.
Old May 14, 2010 | 03:20 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
JW's LED's are de best
Old May 14, 2010 | 04:58 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
I also have JW's LED's in all my interior lights and license plate lights and so far no problems.
To Led Flicker
