outside temp gauge
Old Mar 7, 2010 | 06:10 PM
jgauger's Avatar
jgauger
Default outside temp gauge
Where in the 2008 owners manual does it tell how to reset the outside thermometer reading? I have seen it before, but can't find it now. Does anyone know why it has to be reset every few weeks? Thanks
Old Mar 7, 2010 | 06:12 PM
Jeff78's Avatar
Jeff78
I did not know there was such a thing as resetting the temp gauge. Why do you need to do that?
Old Mar 7, 2010 | 06:18 PM
RicK T's Avatar
RicK T
Not in the Onwer's Manual, it's in the Service Manual:
http://forums.corvetteforum.com/1565360581-post23.html
jgauger's Avatar
jgauger
Default outside temp reading
Because it is 55 degrees outside and it reads 75 degrees. I have reset it before , but I forgot how.. It involves the 2 defrost buttons and the fan switch I think, but maybe not, since I can't do it now.
Old Mar 7, 2010 | 06:20 PM
jgauger's Avatar
jgauger
Thanks, that's where I went wrong.
Old Mar 7, 2010 | 06:32 PM
65GGvert's Avatar
65GGvert
It doesn't have to be reset every few weeks. Or at all for that matter. That procedure only allows instant reading instead of the automatically stored recorded data which will be updated as you drive anyway. Pushing the buttons described doesn't reset, merely allows faster reading for current temperature.
2006c6keller's Avatar
2006c6keller
Default Temperature delay is normal.
It usually takes the temperature sensor approximately ten (10) minutes to up date from when you last used the car. For example: It is hot outside and the A/C was working fine and you stop the car and come back an extended time later and restart the car and now the computers would be messed up with ALL the new temperature readings inside and outside of the car and now it takes the "consertative" approach and uses the last settings for a short time. There is something in the manual on this temperature delay when restarting the car.
Old Mar 7, 2010 | 06:44 PM
Zymurgy's Avatar
Zymurgy
Moderator
Original posted by Paul (Talon90) and is the post linked above by Rick T:
Service manual.
Condition
Display
At start up with the engine OFF more than 3 hours
Displays actual outside temperature
At start up with the engine OFF less than 3 hours
Displays last stored temperature
Vehicle moving above 16 km/h (10 mph) for 5 minutes
Updates temperature display at a slow filtered rate.
Vehicle moving at 51 km/h (32 mph) or greater for 2.5 minutes
Updates temperature display as rapidly as possible.
When the sensor reading is less than the displayed value.
When the Front Defrost, Rear Defog and fan up buttons are pressed simultaneously.
Updates temperature display instantly.
Old Mar 7, 2010 | 08:23 PM
jgauger's Avatar
jgauger
I appreciate all of the advice. Sometime mine will read 106 degrees when it is only in the 80's outside. I understand about the updating automatically depending on the circumstances, but mine does not seem to reset to the correct temp no matter how long I wait. It only changes 1 degree when I reset it using the above mentioned method. I must have a glitch somewhere.
Old Mar 7, 2010 | 08:38 PM
cclive's Avatar
cclive
The sensor sits right next to the radiator, so after being driven and then stopped, the sensor would pick up that extreme heat if it did not have the delay built into its software. The sensor needs airflow across it to become accurate...if all your trips in the car are short, it may never get past the software timeframe.
Old Mar 7, 2010 | 08:40 PM
ProudAmerican's Avatar
ProudAmerican
Hey, anybody here remember being a Boy Scout and you would learn how to tell the weather with a "string on a stick."
P.S. (owa tagoo siam) for all my follows Scouts
Old Mar 7, 2010 | 09:13 PM
Zymurgy's Avatar
Zymurgy
Moderator
Originally Posted by ProudAmerican
... P.S. (owa tagoo siam) for all my follows Scouts
I learned it as owa tanaw siam
Old Mar 8, 2010 | 09:11 PM
2006c6keller
Default Good point!
Good point!
To outside temp gauge
