how does onstar work?
Old Mar 8, 2010 | 04:13 PM
Demonicbird00's Avatar
Demonicbird00
Default how does onstar work?
did a search..no results
how does it work? does it work through the radio or have its own box/unit?
id prefer to get a vette w/out it
thanks
brandon
Old Mar 8, 2010 | 04:14 PM
Vette_DD's Avatar
Vette_DD
It has its own box at the top of the passenger side windshield. There's also a microphone on the driver's side "A" pillar.
Old Mar 8, 2010 | 04:27 PM
Zymurgy's Avatar
Zymurgy
Moderator
, but it also uses the audio system for audio output.
Old Mar 8, 2010 | 05:57 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Onstar uses the VCIM (vehicle communications interface module) which also happens to pass through Class 2 serial data. It also requires a specific antenna which as noted is mounted to the upper right side of the windshield. Also as noted it uses parts of the audio system and microphone for communications with the driver.
While you can't simply remove the VCIM (although it can be done) you can easily disable Onstar by pulling the fuse for Onstar in the fuse panel.
Old Mar 8, 2010 | 06:01 PM
jackcasa's Avatar
jackcasa
"While you can't simply remove the VCIM (although it can be done) you can easily disable Onstar by pulling the fuse for Onstar in the fuse panel."
That's a great idea!
To how does onstar work?
