ABS Module ?
Old Mar 11, 2010 | 09:27 AM
BAMAGOLFER's Avatar
BAMAGOLFER
St. Jude Donor '06-'10-'11
Default ABS Module ?
Is the ABS module the same on the C6 & ZO6? If not anyone have the part #'s ?
Kelly
Old Mar 11, 2010 | 12:06 PM
BEZ06's Avatar
BEZ06
Kelly
I dunno - but here's a bump TTT for ya!
Until a real expert chimes in, take a look at this webpage:
http://www.compnine.com/index.php?u=...04&grouptype=B
This is for 2005-2008 cars, and the 2 parts that make up what we call the EBCM (the BPMV-Brake Pressure Modulator Valve; and the EBCM-Electronic Brake Control Module) are both identified as AC Delco parts. I believe it was on the 2009 model year and newer that these parts are from Bosch and would have different part #s.
You can see some letter/# codes associated with each part. Y07 is a coupe, Y67 is a vert, and Y87 is a Z06. Also, JL9 is the brake system for a base Vette (basically the rotors/calipers/pads), J55 is the Z51, and J56 (which isn't mentioned on that page) is the Z06.
So.....It looks like the base C6 and the Z06 use the same part #s. Item# 004 on that webpage is listed twice (for the Y07-67, and for the Y87) but the part# is the same. It does say programming is required - but your dealer will program the unit with a Tech 2 for which ever car you have.
Hopefully a real knowledgeable expert can give you more info.
Bob
Old Mar 11, 2010 | 02:53 PM
BAMAGOLFER's Avatar
BAMAGOLFER
Thanks BEZO6!
Old Mar 12, 2010 | 09:18 PM
HavinSomeFun's Avatar
HavinSomeFun
I'm showing part number 89060303 for the valve kit and 89060341 for the module kit. These are the 2 parts that make up the unit. Both numbers are a kit that includes other items to complete the set up. I show only one setup for both the Z and the non Z... Hope that helps.
To ABS Module ?
