Reverse lights
Old Mar 11, 2010 | 05:08 PM
H2Times's Avatar
H2Times
Default Reverse lights
Can someone tell me how best to go about replacing the back up light bulb? How do you remove the lens?
Old Mar 11, 2010 | 05:32 PM
Deiger's Avatar
Deiger
You can do it with the rear end jacked up or not. I did it without jacking the car.
Lay on our back to the right or left of your exhaust. Reach one arm underneath the black diffusor. Grab the bulb socket and turn. It will only turn one way. Pull the bulb out of the socket and replace. Now reverse the above procedure.
Duplicate your efforts on the other side. Go slow as patience is needed, along with some flexibility.
Deiger
Old Mar 11, 2010 | 05:51 PM
H2Times's Avatar
H2Times
Deiger
Got it. Thanks!
Old Mar 11, 2010 | 05:54 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
LED super bright reverse lights at JWMotoring.com
http://shop.jwmotoring.com/product.s...8&categoryId=6
Zymurgy's Avatar
Zymurgy
Moderator
Lay on your back to the right or left of your exhaust. Reach one arm underneath the black diffusor. Grab the bulb socket and turn. It will only turn one way. Pull the bulb out of the socket and replace. Now reverse the above procedure.
Deiger
That is how I replaced my stock bulbs with LEDs.
Old Mar 11, 2010 | 05:59 PM
LS WON's Avatar
LS WON
Just plug the LED's in? $60.00 for a pair?
Old Mar 11, 2010 | 06:12 PM
Zymurgy's Avatar
Zymurgy
Moderator
Yep, just plug them in. $40-$60 per pair depending on which ones you choose. $50,000+ car, $60 bucks for the lights is no biggie. One of the lowest cost "mods" you can do.
Old Mar 11, 2010 | 06:14 PM
///DarkSide\\\
JW's are $30
Old Mar 11, 2010 | 07:54 PM
tjl5709's Avatar
tjl5709
How much brighter? That is, do they illuminate more than stock bulbs?
Old Mar 11, 2010 | 08:37 PM
///DarkSide\\\
At least as bright or brighter if you get the "super bright" version.
Old Mar 11, 2010 | 08:51 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
From what some of my customers are telling me their brighter.
The main advantage is looks (better white color). Most of the tower leds you see with 39+ leds just aren't brighter (only for looks). These are it!
Wait until the next version I have in the works comes out. 6.5 watts of led power
All of our leds come with a money back guarantee. If you don't like them send them back for a refund
Old Mar 11, 2010 | 09:30 PM
///DarkSide\\\
Originally Posted by jw@jwmotoring.com
wait until the next version i have in the works comes out. 6.5 watts of led power
eta ?
Old Mar 11, 2010 | 10:49 PM
LS WON's Avatar
LS WON
What's the wattage on the factory bulbs?
Old Mar 11, 2010 | 10:53 PM
LS WON's Avatar
LS WON
Old Mar 12, 2010 | 05:19 PM
H2Times's Avatar
H2Times
Well, I just installed the back up LED's from JW. They look pretty bright to me.
Old Mar 12, 2010 | 05:57 PM
LS WON's Avatar
LS WON
Any pics?
Old Mar 12, 2010 | 06:03 PM
JW Motorsports
Banned Scam/Spammer
eta ?
Probably 3 weeks or so. They're 6 watts not 6.5 like I originally said.
Not sure on stock bulbs.
Old Mar 12, 2010 | 06:09 PM
LS WON's Avatar
LS WON
Old Mar 12, 2010 | 09:56 PM
Deiger's Avatar
Deiger
For the time being I got some Super Whites from Autozone to match my JW license plate lights. They do put out more light to the rear.
Interested to see what JW has up his sleeves.............
Deiger
To Reverse lights
