C6 build code info plate?
Old Mar 21, 2010 | 12:42 PM
kevakasper's Avatar
kevakasper
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Default C6 build code info plate?
I have seen the option codes printed on plates on c5 vettes inside the drivers door, I looked at my 06 c6 and nothing there. Where did they put the option code plate on the c6's, I would like to know what rear end gear etc. my car has. Is there any way to get the info from GM via the VIN #? Thanks in advance.
Old Mar 21, 2010 | 01:00 PM
cclive's Avatar
cclive
It is on the inside left of the glovebox door.
Old Mar 21, 2010 | 01:29 PM
kevakasper's Avatar
kevakasper
Thanks for the info!
Old Mar 21, 2010 | 04:55 PM
AFVETTE's Avatar
AFVETTE
You can get a new Window Sticker and Build Sheet for your car from the NCM
https://store.corvettemuseum.com/ser...buildsheet.asp
Great accessories if your car didn't come with them.
Cheers
Tom
Old Mar 21, 2010 | 06:21 PM
calemasters's Avatar
calemasters
As for the build date, the mm/yy are printed on the FMVSS certification label which you can see when the left door is open. However, if you the build date by mm/dd/yyyy the dealer can provide that on a VIS print out.
To C6 build code info plate?
