adding subwoofer in c6 vert
Old Mar 22, 2010 | 12:32 AM
noenvybu's Avatar
noenvybu
Default adding subwoofer in c6 vert
has anyone added a small subwoofer in a C6 vert,and still had any trunk space?? If so, any suggestions on sizes and set-ups, would be appreciated...pics would help
Old Mar 22, 2010 | 01:46 AM
Fredro Starr's Avatar
Fredro Starr
This isn't mine but mine looks the same except for the cashmere interior.
I went with the stealthbox. No reduction in trunk space.
Old Mar 22, 2010 | 07:26 AM
AT T 2D's Avatar
AT T 2D
I went with the stealthbox as well. It sounds very good, but doesn't have incredible bass due to the very small enclosures. I do think it is the best option out there that I have seen.
Old Mar 22, 2010 | 10:24 AM
shownie's Avatar
shownie
Try www.madvettemotorsports.com, Dave can hook you up.
Best of Luck with your search!
Old Mar 22, 2010 | 10:59 AM
NYC6's Avatar
NYC6
I have a JL Stealthbox in my Coupe and love it, if I had a Vert I would go with the JL's as well. The woofers are right behind you and will sound better than a larger sub taking up valuable space in the severely limited trunk.
Old Mar 22, 2010 | 11:01 AM
PAKev's Avatar
PAKev
I added a self-powered Infinity BassLink. It's pretty small and sounds great...and can be had for under $200.
The one thing I noticed with a sub in the trunk...it has a relatively high cutoff frequency...so the really deep lows are muted somewhat. I'm guessing about 50-60 Hz. It's not so much a characteristic of the sub but the acoustics of the trunk as far as I can tell. After listening the Infinity and realizing the really low frequencies were dampened, I temporarily installed a larger sub enclosure which kicks out some incredible low frequencies in my Nissan Murano. It had the same characteristics as the Infinity so again it seems to be more a characteristic of the trunk acoustics. However, the Infinity made a HUGE difference in sound over not having it...particularly with XM which really seemed to have very limited bottom end. With CDs and iPhone, it really kicks! This was added to the stock system.
Old Mar 22, 2010 | 11:16 AM
LA-TAXI's Avatar
LA-TAXI
They must think those things are made of gold! Kinda pricey!
Old Mar 22, 2010 | 11:28 AM
PAKev's Avatar
PAKev
That's the conclusion I came to...why I went with the Infinity Basslink. The Stealthboxes do look slick though.
There are some excellent install tips on this sticky...it took about 3 hours to install:
http://forums.corvetteforum.com/audi...audio-faq.html
Old Mar 22, 2010 | 09:33 PM
Fredro Starr
ALL JL stealthboxes are pricey. I was going to get one for another vehicle and it was equally as pricey. Ended up getting a mold made of the area I wanted to fill and added the JL sub. It was cheaper but not by a whole lot. Unsure if you could go the same route with the Vette.
To adding subwoofer in c6 vert
