Need help, resistors for switchbacks
Either the amber or white is always lit up when your turn signal is on.
As a matter of fact, I would say that the only time that the switchback lights are totally off is when the car is turned off.
Once the lights are turned on they turn white. When you use your turn signals they switch back and forth.
If they do not function that way something triggered the white circuit to stay on. Usually they are tested in a garage or shop with the ebrake in use. They won't work properly this way.
In order for them to work as advertised they must be used as the car would be driven. That means you must test them out on the road while the car is running.
I have heard of a couple of C6s where they just wouldn't work correct. I couldn't figure out the problem since I wasn't there for troubleshooting. I just had to go by what the owner told me they tried. After receiving the bulbs back they tested fine in my car so I just came to the conclusion that some c5s/c6s don't like the bulbs. That's really rare though.
Try reversing the plug.
My Switchbacks, yet to be installed, are 'wired' the same way as yours Ken.
It's kind of odd that the lamps, either LED or Incandescent (OEM) have 4 pins and the connector has 3.
Yes I know the grounds are shared, but if you looked at the plug's pic in the Service Manual, you'd think there's no way it's going to make good contact with all 4 pins.
But obviously the connector works, and there is only one way to plug in the LED 'bulb' to get anything to work at all.
I still have no idea why the OP's adding of load resistors would cause the switchback function to quit working. I wonder how they are switching the white LED's off when the amber ones come on, either flashing as turn signals or constantly on as DRL's.
This last condition is the reason I haven't installed mine. They were an impulse buy but further investigation with the manufacturer revealed that they claim running them as DRL's will cause premature failure.
I assumed it was because the switching circuit would fail.
And to confirm the color code on the OEM connector, Black's ground, Brown's parking/running lamp voltage and Blue/White is turn signal/DRL voltage.
with load resistors: no hyperflash but white stays on always
without resistors: hyperflash but ACTUAL switchback (amber then white then amber then white...)
got em from JW Motoring. anybody..?
