Squeaky top
Old Mar 23, 2010 | 06:34 PM
V's C6's Avatar
V's C6
2nd Gear
Default Squeaky top
Having an issue with coupe top on My C6 squeaking when I have it in the clips in the trunk area..any suggestions??
Old Mar 23, 2010 | 06:38 PM
RnLi's Avatar
RnLi
Super Lube !! Worked great on mine.....both in retention in the trunk AND the infamous top creaking, squeeking, rattle, or whatever while on.
I used the tube type and rubbed it in well. Then wiped off excess.
Old Mar 23, 2010 | 06:57 PM
car2fast4you's Avatar
car2fast4you
I had the same problem.
In my case, it was the the mounting hardware for the plastic clips that was causing the noise.
Using your hand, you can can wiggle the clips a little bit. If one of them makes a squeaking noise using your hand, that's probably your problem.
To fix it, firmly pull straight up to remove the clip. Do it carefully so that you don't break the plastic.
The plastic clip attaches to the car using metal "clips".
I used silicone adhesive to glue all of the metal clips on.
All the squeaking is now gone.
Old Mar 23, 2010 | 07:14 PM
Wayne Enterprises's Avatar
Wayne Enterprises
I've had my 2005 C6 for years now and recently it's making the noise really loudly too. Any other tips?
Does anyone have pics of how to solve this problem? Thanks!
Old Mar 23, 2010 | 07:18 PM
WAwatchnut's Avatar
WAwatchnut
I think the "official" Chevy fix for this is to apply some fabric on the base of the retaining bracket. There's a flat spot on the plastic piece that contains the retaining hook. You can take some self adhesive velcro strips (the fuzzy part, not the scratchy part) and put them on that flat spot. That prevents the plastic to plastic rubbing which often causes the squeaks.
But as Car2fast4you mentioned, if you can wiggle the clips on the top, and get the squeaking noise, it could be that. I had to replace one of my clips when it started falling off every time I took the top out of the hatch. It was definitely making lots of noise back there. But when the noise popped up again, the velcro strip took care of the noise of the rubbing parts.
Old Mar 23, 2010 | 07:23 PM
WAwatchnut's Avatar
WAwatchnut
Here's a pic that I think is from the TSB:
http://forums.corvetteforum.com/1570584790-post3.html
Old Mar 24, 2010 | 02:02 AM
Wayne Enterprises
So this is when it's off and stored in the back?
Mine is squeaking and making noise while it's on the top. Is that where others are making noise as well?
Old Mar 24, 2010 | 02:09 AM
Wayne Enterprises
Actually just saw this post. This is really helpful!
http://forums.corvetteforum.com/c6-c...long-post.html
Old Mar 24, 2010 | 06:01 AM
lastcowboy's Avatar
lastcowboy
thin tape back foam will stop it,,,,,,,,,,plus all the other rattles
To Squeaky top
