services
Old Mar 24, 2010 | 09:31 AM
mdwsr2003's Avatar
mdwsr2003
From: Metro Atlanta (by way of L.A.) Ga (Army Strong Retired)
Default services
what services are due at 30,000 miles and what is the approximate cost
Old Mar 24, 2010 | 11:17 AM
Vette_DD's Avatar
Vette_DD
No special services listed in the owner's manual for 30,000 miles. 25K has the following:
Inspect fuel system for damage or leaks.
Inspect exhaust system for loose or
damaged components.
Remember that Maintenance II items need to be done every other oil change. They are:
Visually check for any leaks or damage. See footnote (g).
Inspect engine air cleaner filter. If necessary, replace filter.
See Engine Air Cleaner/Filter on page 5-25. See footnote (k).
Check tire inflation pressures and tire wear. See Tires on page 5-57.
Inspect brake system. See footnote (a).
Check engine coolant and windshield washer fluid levels and add fluid
as needed.
Perform any needed additional services.
See “Additional Required Services” in this section.
Inspect suspension and steering components. See footnote (b).
Inspect engine cooling system. See footnote (c).
Inspect wiper blades. See footnote (d).
Inspect restraint system components. See footnote (e).
Lubricate body components. See footnote (f).
Replace passenger compartment air filter. See footnote (j).
See Chapter 6 of your owner's manual.
