Yet another battery question?
Old Mar 25, 2010 | 07:29 PM
talionstallion21's Avatar
talionstallion21
Default Yet another battery question?
Stored my vette since November. Last Saturday I took her out of hibernation, re-connected the battery, started her up and all was fine (I didn't take her for a drive since I didn't have insurance back on yet). I left the battery connected because I was going to take a spin tonight. Anyway, tonight, it turned over once and died.
The question is: Is it worth charging the battery or will I just continue to have problems with it? Over the winter I simply disconnected the battery. That has always worked for all my other cars I stored for the winter. Obviously, the vette is a sensitive lass.
For those who have had this experience is it worth charging or should I just get a new battery? Thanks.
My car is an 08 purchased new in 09. It sat on the dealer lot for a year, however. Never had battery problems until now.
Last edited by talionstallion21; Mar 25, 2010 at 10:16 PM. Reason: Pertinent info left out.
Old Mar 25, 2010 | 07:43 PM
kmthor00's Avatar
kmthor00
How old is the vette / battery? I never disconnect my battery, just put battery tender right to battery & forget it.
Old Mar 25, 2010 | 08:13 PM
RICH 28's Avatar
RICH 28
Just charge it up, you should be good to go!
Old Mar 25, 2010 | 08:34 PM
VET4LES's Avatar
VET4LES
You have nothing to lose. It may be time for a new one but try charging it first.
Old Mar 25, 2010 | 08:54 PM
lmbluez06's Avatar
lmbluez06
it has a 3yr 36,000 mile warranty
Old Mar 25, 2010 | 09:43 PM
bob guzzy's Avatar
bob guzzy
If you know or feel the battery is the original, and the car is a 3 or more years old get a new one battery's are not that expensive.
Buy the highest amperage battery that will fit in the space, I try to get 1000 amp battery's when I replace a battery.
Old Mar 25, 2010 | 10:15 PM
talionstallion21
My car is an 08 purchased new in April 09. It sat on the dealer lot for a year, however. I have not had battery problems until now.
Old Mar 25, 2010 | 10:50 PM
Kent1999's Avatar
Kent1999
If it sat on the lot for a year, chances it suffered the same fate as many long-time lot cars -- its highly likely that the battery was run down dead several times and then recharged. Every time the battery goes dead and is recharged, it becomes a little more damaged, and it will not last as long as it normally would.
Bottom line -- even thought its only 2 years old, if it has been run dead several times, it could be time for a new battery.
Old Mar 25, 2010 | 11:00 PM
Astronomer's Avatar
Astronomer
I replaced mine with a Sears AGM Diehard Platinum. No probs with it at all.
Old Mar 25, 2010 | 11:11 PM
cclive's Avatar
cclive
But don't charge it by driving it, put a charger on it.
Old Mar 26, 2010 | 05:55 PM
talionstallion21
OK. Thanks. I'll recharge and if it dies again this year I will get a new battery.
Old Mar 26, 2010 | 05:59 PM
cclive's Avatar
cclive
Battery was on the edge...started once but since it was not driven, did not recharge battery enough to start again. No problem, just charge...and in future, charge once or twice during the winter.
To Yet another battery question?
