Need quick clarification.... (brake pads)
Old Mar 26, 2010 | 08:16 PM
SPANKY LS1's Avatar
SPANKY LS1
Default Need quick clarification.... (brake pads)
True or false: "base" and Z51 brake pads are identical and interchangeable, correct?
I am helping a buddy change his pads on his 2006 coupe, and he has the Z51 brake "upgrade" package (rotors and brackets, but "base" calipers). He bought a set of Z51 pads, they will work in his "base" calipers, correct? I *think* I remember reading that all C6 pads are interchangeable, so these should be fine, correct?
Old Mar 26, 2010 | 08:30 PM
C6NRED's Avatar
C6NRED
Check GM part numbers for both cars.....or give Gene Culley a quick call on Monday morning and find out right away....
Old Mar 26, 2010 | 08:44 PM
Swiftrider08's Avatar
Swiftrider08
pads only = true
As an example:
http://www.corvettegarage.com/produc...-corvette.html
Old Mar 26, 2010 | 08:46 PM
bosco 08's Avatar
bosco 08
They will fit the base calipers. The compound on the Z51 pads may be more aggressive than the base pad but dimension wise they are interchangeable.
Old Mar 26, 2010 | 09:06 PM
cclive's Avatar
cclive
Same pads. In 2006, pads were either Z06 or non Z06.
To Need quick clarification.... (brake pads)
