How to remove plenum covers?
Old Mar 29, 2010 | 11:49 AM
Plourdeman's Avatar
Plourdeman
Default How to remove plenum covers?
Forgive the newbie question, but how do you go about removing the plenum covers on an LS3? I tried searching the this forum for other threads but came up dry.
Old Mar 29, 2010 | 12:35 PM
richhoff's Avatar
richhoff
You probably meant the fuel rail covers? If so, they just pop loose. The one side is very easy to remove. The other one has the fuel line through it. It's best to tape around the opening and work it over the fuel line. Heating it up first by running the engine will make it more pliable and easier to work over the fuel line.
Old Mar 29, 2010 | 12:49 PM
cclive's Avatar
cclive
Do it with engine hot, and they will be noodles. If you do it in the winter and they are cold, there is a possibility of cracking them.
To How to remove plenum covers?
