Need Help With A Lighting Problem !
Old Mar 30, 2010 | 11:06 AM
ZR-1 1991's Avatar
ZR-1 1991
Default Need Help With A Lighting Problem !
I have a 2007 z06 with no nav . Can someone let me know , What switches are backlit with the headlights are one ? Meaning there is a white light that illuminates the switches .i.e. door locks ,power windows heater controls ,stereo , traction control ,heated seats , and a small orange led in the passengers side sun visor clip.
When it is dark ,and I open the drivers door , the backlight work in the power windows and door locks when I close the door they go off , when I start the car none are lit up . Please check yours and let me know what's lit ?
Thanks in advance
Dave
Old Mar 30, 2010 | 12:18 PM
ZR-1 1991's Avatar
ZR-1 1991
There must be somone out there that can check there corvette , and let me know .
Please
Old Mar 30, 2010 | 12:23 PM
mike72's Avatar
mike72
In my 06, all switches are backlit when the lights are on.
Old Mar 30, 2010 | 03:02 PM
ZR-1 1991's Avatar
ZR-1 1991
Hi Mike
Thanks for taking the time to reply ,You been a great help
Old Mar 30, 2010 | 03:05 PM
jackcasa's Avatar
jackcasa
Same with my '05.
Old Mar 30, 2010 | 03:17 PM
beav626's Avatar
beav626
The interior lights have a different sensor.
if it is Sunny out and you turn on the headlights, the interior lights wont come on.
All buttons light up on the inside.
Old Mar 30, 2010 | 05:48 PM
ZR-1 1991's Avatar
ZR-1 1991
Thanks everbody , I will bring car to Dealership to get this checked out and will post follow up . thanks again
Old Mar 30, 2010 | 05:57 PM
Whisky's Avatar
Whisky
Thanks in advance
Dave
Check fuses under the hood. You may have a fuse out. It happened to me!
Old Mar 30, 2010 | 06:18 PM
ZR-1 1991's Avatar
ZR-1 1991
Do you remember which one it was ?
Old Mar 30, 2010 | 06:38 PM
Salt's Avatar
Salt
Same here, good luck at dealership,
Old Mar 31, 2010 | 10:29 PM
Whisky's Avatar
Whisky
Under the hood:
1st row(nearest to you)
2nd fuse from the right or
3rd fuse from the left,
10 amp in the #8 position.
The little diagram says parking lamp.
I didn't realize that my parking lamps were also out at the time as I was focused on the interior control lighting not working.
Old Nov 5, 2024 | 01:15 AM
Tom2005issue's Avatar
Tom2005issue
Thanks in advance
Dave
has anyone found out the problem just happened to me word for word and I'm getting worried it's gonna be expensive
To Need Help With A Lighting Problem !
