AC. Problem
Old Apr 10, 2010 | 11:17 AM
V RED 08's Avatar
V RED 08
Default AC. Problem
C6 08 Auto-8000 mi.
System is producing no cold air. The only thing I notice is the Recirculation button (Beside Auto Button) lights up about 10 sec. after I put system in Auto Mode. Is that normal?
Any suggestions before I go to dealer?
Old Apr 10, 2010 | 12:23 PM
Capt Steve's Avatar
Capt Steve
You are probably low on refrigerant (R134a). You could have a leak in the system. I would just take it to the dealer since you are still under warranty. These systems should not leak, especially on such a new car.
Don't let them just refill the system. The dealer should put a dye into the system to help find the leak. Finding a leak is not always an easy thing to do, and can take a long time. Don't let them off the hook.
The recirculation comes on because the AC is trying to lower the temperature faster. The theory is that by recirculating cold air rather then mixing in warm air, the temp goes down faster.
Old Apr 10, 2010 | 12:57 PM
VET4LES's Avatar
VET4LES
Good information.
Old Apr 11, 2010 | 01:29 PM
V RED 08's Avatar
V RED 08
Thanks for your help. Is it possible the compressor is leaking or is it more likley a loose connection in the system?
To AC. Problem
