Which Flat Kit do you recommend?
A little pricey but then you get what you pay for and dealing with a flat is not the time to find out the el cheapo Wally World stuff doesn't work as described.
Tom
Something else to really think about, and I have had to fix two flats in the field, is to go to a local junkyard and get a small jack. The one I have is self contained and has a nice head on it that fits perfectly in the area for the pucks. I also have a 1/2 breaker bar, and a lug socket. I had a screw on the inside rear, and it was bad enough to allow the air to leak out pretty quickly, so driving on it was not an option. It was also in a place where it was very difficult to get to. I had to remove the tire.
The other situation was a screw buried deep with the head broken off. The only way I could get it out was with needle nose pliers.
Also add a blanket to lay on
Rubber Gloves, this is a filthy job
A small bottle of water to check the patch, and to drink.
A headlamp for those dark moments
Needle Nose Pliers
A flat head screwdriver
All of this sounds like a lot, but all of mine would fit in the two cubby's. I have a nylon stuff sack from REI that holds everything.
For those that think they can simply call their road Service, double check your coverage as most, if not all, will NOT PATCH a tire, but put on a spare, leaving you SOL. My AAA agreement spells that out very clearly.
Another reason to be fully prepared, is I called AAA for a tow on a flatbed, the only one available in my area was already booked for two tows in front of me, so it was a minimum 2+ hour wait. All bets are off for a time guarantee, when you have to ask for a specific type of tow/flatbed.
Needle Nose Pliers
Ill stick with the run-flats The Best of Corvette for Corvette Enthusiasts
Needle Nose Pliers
Tom
I have RF's on my C6, but when I had my C5, I was non-RF for 12 years, and only had 2 flats.
It cracks me up when I see guys say they have a cell and AAA. That works, but in my case it was a 2+ hour wait for a flatbed... no thanks.
Many of the places I go, Yosemite, Death valley, and the Sierra high country, there is no cell coverage. That is why I stuck to RF's on the C6.
I am very, very happy with the Michelin ZP's. But had no qualms driving on Nitto 555's on my C5 as a daily driver either.
Both have a place, it's up to the individual to determine what's important.
For a DD that doesn't go far from home I could live with a non run flat, but if you travel far and to off beat locations I'd think twice about that.
Tom
Cellphone with car charger.
AAA membership
Glock[/QUOTE]
Glock?
Which one? G-17 or G-21
Griot's Garage has one it maybe overkill at $99.00
RMX
Needle Nose Pliers
I'm getting non-RF's because of the above logic.. but RF's have their place.. If I did a lot of out of town traveling, etc... I would stay with RF's.
Loud- I can't hear tires over my exhaust
Poor Handling- You can't push that car hard enough in the street to get poor handling and If you track it you should use track tire.
noisy- see loud
