Lexan Tops
Old Apr 16, 2010 | 06:25 PM
lawnmore's Avatar
lawnmore
Default Lexan Tops
Just bought and installed an 09 Lexan top on my 07,any advise on care of the surface,both inside and out, do's and don'ts ETC?
Old Apr 16, 2010 | 06:39 PM
haljensen's Avatar
haljensen
Wash, rinse and dry just like the rest of the car. If you use glass cleaner make sure it's ammonia based, not alcohol based (per the Owners Manual).
Old Apr 16, 2010 | 07:51 PM
LazyDog's Avatar
LazyDog
Acetone specifically will eat up and destroy Lexan. Avoid getting this anywhere near the top.
Old Apr 16, 2010 | 08:50 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Mild soap and water, really nothing else is necessary.
Old Apr 16, 2010 | 11:12 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Be sure to gently wash the outside of the top before doing anything else, flooding with lots of water. You don't want to be grinding grit into the plastic.
GM sells a glass cleaner that is approved for the lexan top and also works well on other clear plastic, like the gauge faces.
The cleaner comes out of the spray can as a kinda white foamy stuff, doesn't look or smell lke it would be very effective. But I've stopped using Stoners on my real glass, the GM cleaner seems to work just as well and won't attack plastic.
To Lexan Tops
