C6 Question
Old Apr 22, 2010 | 07:54 PM
Dads C5's Avatar
Dads C5
Default C6 Question
I've been looking at an '07 coupe. It was a lease vehicle and has 41K on the clock. I did a car fax on it and found that at 35K miles it had all the sway bar bushings and end links replaced. Also at the same time, the PCM was reprogramed. Can anyone give me some insight as to what the problem may have been? Thanks in advance.
Old Apr 22, 2010 | 08:19 PM
LMBTom's Avatar
LMBTom
Bushing and end links wear out and start to make noises. Have no idea what a PCM reprogram was for..
Old Apr 22, 2010 | 08:21 PM
calemasters's Avatar
calemasters
You will need the labor op to determine why the PCM was reprogrammed. A dealer can look it up in VIS.
Old Apr 22, 2010 | 08:26 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
and as calemasters said, any GM dealer can access the proprietary VIS system by giving them the VIN from the car. the end links and bushings isn't a severe issue. but it will be interesting when you tell us why the PCM was redone.
Old Apr 22, 2010 | 08:38 PM
goatts's Avatar
goatts
Walk away. That's high miles too.
Old Apr 22, 2010 | 08:46 PM
Dads C5's Avatar
Dads C5
Thanks all for the info. I used to work with the service manager at the chevy dealer. I will give him the info and see what he says. Thanks again.
To C6 Question
