Turning everything on without starting engine?
Old May 1, 2010 | 02:04 AM
jeremyjay46's Avatar
jeremyjay46
Default Turning everything on without starting engine?
Is there a way to turn everything on, without starting the engine? In other words, not just accessory mode... but full mode where the gauges come on. I needed to use a scan tool the other day to clear a code for CAGS (fuse). It said to turn ignition on, but do NOT start the engine. I haven't read anywhere how to do this. Reluctantly I just went ahead and started the engine, and cleared the code with it running, but I figured there has got to be a way....?
Old May 1, 2010 | 06:12 AM
tjl5709's Avatar
tjl5709
I've herd were if you floor the gas peddle while trying to start it, it will only turn over.
This is how some guys bring there cars out of hibernation after a winters sleep to prime the oil system.
Search for posts as I have never done it.
Old May 1, 2010 | 07:54 AM
JRHAWK9's Avatar
JRHAWK9
press down and HOLD in the start button. Instead of just pressing and releasing it to enter "accessory" mode, just keep holding it down until everything comes on. It will then turn everything on just like the car is when it's running, but without starting the engine.
Old May 1, 2010 | 08:04 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
What does your manual say?
Press and hold THE BOTTOM of the start button until everything turns on.
Old May 1, 2010 | 08:08 AM
65GGvert's Avatar
65GGvert
Hold the bottom for about 5 seconds.
Old May 1, 2010 | 03:15 PM
jeremyjay46
My MANUAL is in the car, in storage. If that is your response, you have a LOT of posts to respond to. (I think there have been several posts asking why their manual car forces them to shift from 1-4th?)
Thanks guys! I appreciate it.
Old May 1, 2010 | 04:29 PM
cclive's Avatar
cclive
If you have a manual transmission, you can also push the start button just as normal but don't push in the clutch. It will turn ignition on and not kick over the starter.
Old May 1, 2010 | 04:35 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
NEGATIVE.
This does NOT turn "everything on". It only turns on those items powered by the "accessory position".
Items powered in "run" mode are NOT powered up by this method.
Old May 1, 2010 | 07:29 PM
cclive's Avatar
cclive
Actually, if you hold the bottom part of the button for a few seconds, it does the same thing as trying to start the car without the clutch pedal pushed in...it turns the ignition to "on"...everything is on except the engine is not running....the equivalent of turning the key to the "run" position without cranking the engine on an old fashioned car that uses a metal key.
From page 201 of my 2007 manual...
"Press the bottom of the Acc. button on
the instrument panel and hold the button down for
five seconds. The instrument panel, including the
check engine light, will light up and the ignition will
be on, but the engine will not start—"
Old May 1, 2010 | 07:35 PM
KenHorse's Avatar
KenHorse
Nope, at least not on my '07.
the procedure you mention only turns on "accessories". Other electrical items that are only powered while the car is in "full running mode" are NOT activated.
It is NOT the equivalent of " turning the key to the "run" position without cranking the engine on an old fashioned car that uses a metal key"
Sorry but it is not
Old May 1, 2010 | 07:38 PM
cclive's Avatar
cclive
Try it...hold the button down for 5 seconds as the manual says...and the fob must be inside the car just like if you were going to start it...I quoted the page from the manual...
Old May 1, 2010 | 07:42 PM
mpuzach's Avatar
mpuzach
Sorry but it is not
OK, then please tell us what doesn't come on by depressing and holding the bottom of the toggle switch. I don't know about your car, but in mine it turns on the A/C, the DIC, the DVD drive, and other things that I can hear even though I don't know what they are. I get power to a lot of stuff that doesn't come on when I'm in accessory mode.
KenHorse's Avatar
KenHorse
I just walked out to my '07 and tried it.
I knew I was right before I did it and confirmed that fact.
You're misinterpreting the manual - I just took a look and didn't see anything that indicated any differently than I've been saying.
Old May 1, 2010 | 07:45 PM
KenHorse's Avatar
KenHorse
Really? The instruments don't come alive (although the DIC does say "Accessory Mode" or something like that - I can go back out and get the exact verbage I suppose) in mine. Nor does my Radar Detector which is powered from the rear view mirror. Also I have a 2 way radio that is only powered when the car is running. It also does not power up via the method described.
Perhaps the firmware for the computers was changed in later years but as I said, my '07 does NOT power up everything
Old May 1, 2010 | 08:05 PM
cclive's Avatar
cclive
You're not holding the button long enough. It takes a good 5 or 6 count and then it turns on the DIC, instruments, radar detector, headlights (if you are in a garage)....everything except the engine. The DIC will go through the same start up sequence as it does when you start the car.
Take a look at page 201 of your manual
Old May 1, 2010 | 08:09 PM
KenHorse's Avatar
KenHorse
OK, I am officially spanked!!
I was holding the button down for less than 5 seconds. If I hold it for longer than 5, then voila! Everything does seem to power up.
I stand corrected
(and always learning something new about these cars!)
Old May 1, 2010 | 08:12 PM
cclive's Avatar
cclive
I would have started doubting myself but yours was a 2007 also.....
To Turning everything on without starting engine?
Old May 2, 2010 | 02:10 AM
jeremyjay46
Glad we got that sorted out. =)
Old May 2, 2010 | 06:18 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I agree!
Old May 2, 2010 | 06:42 AM
VettinFan's Avatar
VettinFan
Bingo!
