Climate control display blinking
Old May 4, 2010 | 08:02 AM
xX BUD Xx's Avatar
xX BUD Xx
Cruise-In X Veteran
St. Jude Donor '09-'10
Default Climate control display blinking
'08 coupe. While driving to work this morning, the display for the climate control began to flash on and off. Very steady flash.
Unit is still functional. Turned opower off and turned the car off, neither resolved the issue.
I will disconnect the negative battery lead tonight.
Anyone else had this issue? Car is 7xx miles out of warranty.
Old May 4, 2010 | 08:42 AM
havesleep's Avatar
havesleep
My 2007 vert would do the same thing. It would resolve itself. I believe it is a connection problem. I just never had the time to take it into the dealer.
Old May 4, 2010 | 08:51 AM
xX BUD Xx's Avatar
xX BUD Xx
Cruise-In X Veteran
Thank you, sir. I'll tear into it this weekend.
I was just curious if anyone sles had the same problem.
Old May 4, 2010 | 11:14 AM
nomo50's Avatar
nomo50
Hey,
My 08 did the same thing, it was intermittent.
Like you said. it still works but blinks.
The dealer finally replaced the A/C head unit, no problems since.
Old May 4, 2010 | 11:43 AM
CQRT's Avatar
CQRT
The display on my 2005 periodically just went blank - - sometimes it came back on by itself, other times responded positively to a sharp 'thwack' of my fist.
I began thinking sooner or alter I would probably crack the display, so took it in to the dealer- they replaced it under my extended warranty - - hasn't been a problem since.
Old May 4, 2010 | 01:48 PM
xX BUD Xx's Avatar
xX BUD Xx
Cruise-In X Veteran
Started the car to go to lunch and the display is normal.
To Climate control display blinking
