Odometer Tampering
Old May 5, 2010 | 02:49 AM
C6_Z51Edmonton's Avatar
C6_Z51Edmonton
2nd Gear
Default Odometer Tampering
Fellas,
I just bought this car today sight unseen http://www.drewford.com/inventoryDis...ost=El%20Cajon
It has low miles and everything appears to be in good shape excepts the 6-9 area on the steering wheel, I'm wondering if anybody else has seen wear on their steering wheels at this mileage? I suggested to the salesperson that I was worried that the odometer may have been tampered with but he assured me that if it were it would have been revealed when they plugged it into their computer during the inspection, do you know if what he is describing is even possible?
I know people who have disconnected the odometer/speedometer or put a toggle switch in so that they can turn it on and off in order to keep miles low on the vehicle and keep it on warranty. The CARFAX doesnt report odometer tampering but there also aren't any reports between the time it was new and now.
I appreciate the help and opinions.
Old May 5, 2010 | 05:10 AM
bolivar's Avatar
bolivar
My 2007 has less than 11,000 miles.
No tampering.
Lots of Corvettes are driven very little.
Old May 5, 2010 | 07:56 AM
KneeDragr's Avatar
KneeDragr
Maybe you should show the marks to those people you know, since they might be able to recognize them.
Old May 5, 2010 | 08:08 AM
L82Brake's Avatar
L82Brake
Take down the VIN and stop by your Chevrolet dealer. Very nicely ask the service writer, service manager etc to look up the service history. Tell them your a potential new customer. The service history will tell you a lot.
Old May 5, 2010 | 08:14 AM
redzone's Avatar
redzone
Not sure what caused those marks,but I don't know anyone who drives with their hands in that position,so I wouldn't consider that a clue to tampering with the odomerter.
Old May 5, 2010 | 08:18 AM
grumpy63's Avatar
grumpy63
Could be marks from a steering wheel locking device such as a "club"??
Old May 5, 2010 | 08:40 AM
Top_Fuel's Avatar
Top_Fuel
Originally Posted by C6_Z51Edmonton
I just bought this car today sight unseen...
Sight unseen???
I can't tell what those marks are. Could be wear, could be some substance on the steering wheel from the guy who just detailed it, or ??? The last thing I would suspect is odometer fraud.
Old May 5, 2010 | 08:41 AM
MARSC6's Avatar
MARSC6
The damage is probably from rings. The location of the damage is where I normally hold the wheel since I steer with my left hand.
Old May 5, 2010 | 08:47 AM
fastter's Avatar
fastter
We had a VW Passat at work that our GM drove. She used a lot of hand lotion. That's exactly what her steering wheel looked like.
Old May 5, 2010 | 08:52 AM
SRQStingray's Avatar
SRQStingray
Photo of steering wheel shows some abrasions all along the wheel. Somethings goofy.
Old May 5, 2010 | 08:54 AM
ArcticLS3's Avatar
ArcticLS3
Could be a car the guy used on the track a lot or something - low miles, but lots of input into the steering wheel.
Old May 5, 2010 | 08:56 AM
Hutch45's Avatar
Hutch45
Wounded Warrior Escort '11
Could it be from the previous owner's method of getting in and out of the Vette?
Obviously, it bothers you, so I would call the previous owner and simply ask he/she.
Old May 5, 2010 | 09:01 AM
not08crmanymore's Avatar
not08crmanymore
Well,that's the first Vette I've seen with the wheel that bad.However, GM does not put high grade material in our Vette's,that no secret. Apparently,whoever owned it always held the wheel there and their skin oils have had an effect which is what you're seeing most likely.I wouldn't worry about rollback because there to many ways to find out and checking service history or Carfax/autocheck are 2 of them.I'd be more concerned of why it's a BUYBACK VEHICLE and depending on that,I wouldn't pay top dollar for it either.
Old May 5, 2010 | 09:41 AM
BRCC's Avatar
BRCC
No disconnection or toggle switch can accomplish that in the new systems. The PCM/ECM generate/calculate/store milage and transmit via the BCM to the gauges. Therefore those units would need to be tampered with, scan and tune tools have not been known to alter the milage. I am sure there are methods but it's a Federal Offense and I don't think it would be worth anyones effort if caught.
Old May 5, 2010 | 10:08 AM
Blevinator's Avatar
Blevinator
Negotiate a new wheel with the dealer.
I have seen cars with 7k have seats that look worn out. Your car was probably
driven by somene with really rough hands.
Old May 5, 2010 | 10:12 AM
Blevinator's Avatar
Blevinator
Ad says buyback guarantee,not buyback vehicle.
Old May 5, 2010 | 10:59 AM
JTS97Z28's Avatar
JTS97Z28
No I would not worry about odometer fraud as its not not something easy to do in these cars.
As for the steering wheel everyone pretty much covered it already could be from hand lotion, rings, use of the wheel to get in and out of the car etc etc. Anything can cause that if its actually wear on the wheel and not something that can be cleaned off then I would simply replace with a new steering wheel and she will be like new again.
James
To Odometer Tampering
Old May 5, 2010 | 11:16 AM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
I see a DSVETTES steering wheel in you future.
Old May 5, 2010 | 07:22 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Suggestions:
1. Clean up steering wheel as much as practical.
2. Inspect rest of car for possible work needed- fluid changes, suspension alignment, etc.
Perform any work needed.
3. Enjoy the car; try to wear it out by driving, including some hard driving.
Bet you can't wear it out!
Old May 5, 2010 | 08:01 PM
cclive's Avatar
cclive
I would not worry about it...and the only thing that you can be sure of is that the dealer never plugged the car into their computer...I'd be surprised if they did anything more than wash it.
