Radiator sticker trashed
Old May 11, 2010 | 02:55 PM
CessnaDriver's Avatar
CessnaDriver
Default Radiator sticker trashed
I dunno what happened, I must have wiped it down with something and it's a blurred mess. Anyone have a source for a replacement or part number?
Old May 11, 2010 | 03:06 PM
frogmore's Avatar
frogmore
what kind of cessna?
Old May 11, 2010 | 03:12 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
The label in question is called the AC refrigerant caution label and it is GM part # 10323111 on a 2005. It is available from any GM parts counter and it should run you between $16.00 and $20.00
Paul
Old May 11, 2010 | 03:14 PM
AmmoVet's Avatar
AmmoVet
Mine is the same, 2006, and I thought the same thing. But I've seen a few C6's with the same problem.
Old May 11, 2010 | 04:11 PM
keith5's Avatar
keith5
Active Streak: 90 Days
I've replaced mine once and bought a second.
It's the heat. It just kinda melted away...
Old May 11, 2010 | 04:46 PM
hawkgfr's Avatar
hawkgfr
mine is the same way...
Old May 11, 2010 | 04:55 PM
Bill Suttie's Avatar
Bill Suttie
I thought that the hood blanket abraided mine. I removed it and am not about to spend $20 to replace it.
Old May 11, 2010 | 08:56 PM
CessnaDriver
Sounds like it may happen again.
I thought to spray a protective clear coat over it though.
CessnaDriver
The single engine bug smasher variety.
Old May 11, 2010 | 09:00 PM
Vasta's Avatar
Vasta
St. Jude Donor '06-'07-'08-'09-'10-'11-12-'13-'14-'15-'16
Why replace it? I took mine off years ago, but I did save it in a plastic baggy.
Old May 11, 2010 | 10:09 PM
LMBTom's Avatar
LMBTom
Took mine off a few days ago and cleaned it up. Now looks better than ever. Don't need no stinkin' stickers telling me what refrigerant I need to use anyway
Old May 11, 2010 | 10:48 PM
z06Bigbird's Avatar
z06Bigbird
Easy way to spot a car with front end damage: No stickers under hood/on radiator cover, etc.
Just something to think about.
Some of these stickers are about $40. Create a new one on the pc and laminate it.
Old May 12, 2010 | 12:24 AM
CessnaDriver
I peeled it off and the melting looks like it was underneath.
So putting on another will likely just happen again.
Cleaned it up and will leave it off for now.
Old May 12, 2010 | 08:30 AM
spinalator's Avatar
spinalator
Same thing happened to me. I cleaned it up and put a Jake sticker there instead.
Old May 12, 2010 | 11:55 AM
hawkgfr's Avatar
hawkgfr
That isn't any more true than saying an easy way to tell front end damage is because all the stickers are new and shiney....
That is a good idea about trying PC though...
Old May 12, 2010 | 12:08 PM
chasboland's Avatar
chasboland
Replace my faded sticker with this:
http://cgi.ebay.com/ebaymotors/CORVE...Q5fAccessories
Fits very nicely and looks like it should be there.
Old May 24, 2010 | 01:50 AM
brucemc's Avatar
brucemc
Has anyone tried using a blow dryer to heat the glue up and remove the sticker?
To Radiator sticker trashed
Old May 24, 2010 | 07:29 AM
AFVETTE's Avatar
AFVETTE
Same here on a 13,750 mile 07 Z06. Wonder why GM couldn't have designed a better decal for that enviroment?
Oh well that's the GM we all know and love. I'm replacing mine with the GM data plate.
Tom
Old May 25, 2010 | 12:19 AM
brucemc's Avatar
brucemc
I was able remove my sticker today off my 2006 by heating it with a blow dryer and peeling it off slowly. It came of pretty easily. There was quite a bit of glue residue left over which I removed by wiping off using an old t-shirt and DW40. Looks great. If someone does this the engine needs to be cold and I'd suggest using a glove for the hand your wiping the glue with. Mine slipped off the edge of the t-sirt and I got burned by the hot glue. Left a nice blister.
Also, I'm sure there may be something better to use than DW40 but I don't know what. Anyone have any suggestions?
I did notice that there are some ridges/rises/lines where two sides of the sticker used to be. I guess it gave GM a good line on where to place the stickers. This took me 10 minutes and was one of the most simple mods for better appearance that I've done.
Old Jul 24, 2010 | 12:34 PM
Lyons16's Avatar
Lyons16
Hi,
I have a 07 Vert and my sticker needs to be replaced also. Does anyone have the GM part number for it?
Thanks, Jerry
