Navigation Disc Read Errors
Old May 13, 2010 | 08:25 AM
CSixDude's Avatar
CSixDude
Default Navigation Disc Read Errors
I'm starting to have more and more problems with my Navigation system saying it can't read the DVD or the "disc is not a MAP DVD" error. It seems like it happens after about 20 -30 minutes of use or if the interior is hot. I've tried a couple different discs with the same results.
I'm wondering if this is a common problem or if there is something wrong with my DVD player. Is anyone else out there having similar problems?
Old May 13, 2010 | 08:38 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Try cleaning the drive. Blowing out with canned air can sometimes do wonders. A car is a very dirty environment for electronics with moving parts.
Old May 13, 2010 | 08:40 AM
CSixDude's Avatar
CSixDude
Yea, I have done this twice already. It seems like it helps for a day or so and then it starts doing it again.
Old May 13, 2010 | 11:30 AM
CSixDude's Avatar
CSixDude
So am I the only one here having this problem?
Old May 13, 2010 | 11:59 AM
RicK T's Avatar
RicK T
Might be something helpful in here:
http://forums.corvetteforum.com/c6-c...n-problem.html
Old May 13, 2010 | 01:47 PM
MusicBiz's Avatar
MusicBiz
I had exactly the same problem - let it go for a period of months hoping it would resolve itself (ha,ha). Eventually the dealer swapped it out for a new unit under warranty. I should have done it much sooner - haven't had a problem in almost a year now.
Old May 13, 2010 | 02:13 PM
CSixDude's Avatar
CSixDude
Thanks, I think I'm going to take it in to the dealer and let them figure it out. I've tried different discs and cleaning to no avail.
Old May 30, 2010 | 12:57 PM
austinC6's Avatar
austinC6
I've also been having what sounds like the same problem. The NAV works fine locally, but if I try to search for an address or go outside my normal driving area, I get DVD read errors. I suspect the drive can't seek correctly.
To Navigation Disc Read Errors
