The panel you are looking for is on the right side interior fire wall behind the floor carpet. Should be labeled on the cover.BTW mines pulled no mild to wild .
I can carry on a conversation with the wifey @ 70mph and I've been told I have selective hearing. Everyone's definition of drone is different.To me it sounds like what a high performance machine should sound like.If it is to loud for you drop it down to 5th and the exhaust will start to "sing".BTW I also have had the "exhaust mod." done to my Z.
As described above, the NPP fuse to remove is located in the lower right position of the fuse block.
You will know immediately if you removed the correct fuse, you will go from basically no exhaust noise at idle to mega exhaust noise.
You may want to consider usage of the Wild to Mild controller as the means to quickly return the exhaust noise level to normal levels in those situations when the Wild mode is simply to loud.
