NPP Standalone vacuum
Old May 16, 2010 | 11:33 PM
Ahmer's Avatar
Ahmer
Default NPP Standalone vacuum
Wondering if anyone has come across doing a stand alone vacuum for the NPP rather than taping into the car system. I am just afraid that by breaking the tiny cap behind the engine bay near where the brak hose is connected, I may run into more problems later...
Ideas?
Old May 17, 2010 | 02:58 AM
AtHomeSoda's Avatar
AtHomeSoda
Default ah..
Ideas?
Again... YOU have a LS2... THAT is NOT where you tap the vacuum... REALLY...
LOOK HERE: http://www.topflightrepro.com/npplite.pdf
Old May 17, 2010 | 09:15 AM
Vettin08's Avatar
Vettin08
And even if you had an LS3, that's where the factory system hooks up to, that's why it's there.
Old May 17, 2010 | 10:23 AM
j_digi454's Avatar
j_digi454
That's not quite correct, those instructions are for that particular vendor, there are other vendors that use the factory setup, see the attached link. I have an LS2 and my NPP vacuum is tapped at the back of the manifold just like a factory LS3 system. It's in the instructions for my kit from Sunset Orange Creations who prefers the factory hookup. Look at post #7 & #18 in the attached link. These directions are for both an LS2 or LS3.
http://forums.corvetteforum.com/c6-c...rofit-kit.html
I preferred the factory setup and the system works perfectly.
To answer the OP's question, I believe it was the Mild to Wild system that originally had a kit with a vacuum pump that was installed in one of the rear storage wells to provide the necessary vacuum. I don't think that kit is still available.
Old May 17, 2010 | 10:57 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I have a different solution - don't install the vacuum line at all and leave the butterflies open all the time!
(anyone wanna buy an unused Sunset NPP In-A-Box?)
Old May 17, 2010 | 11:02 AM
j_digi454's Avatar
j_digi454
That is certainly another option. However, being able to close them is called "co-pilot" option and sure comes in handy when needed. I have to admit, when going on long cruises on major highways, the drone can get a little tiring so it is nice to be able close the valves.
For all other driving, leaving them open is great.
Old May 17, 2010 | 01:14 PM
AtHomeSoda's Avatar
AtHomeSoda
Exactly...
Old May 17, 2010 | 03:37 PM
CH-Z51's Avatar
CH-Z51
From: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
Xs 2
To NPP Standalone vacuum
