Brake issues
Old May 18, 2010 | 07:05 PM
Kaldar's Avatar
Kaldar
Default Brake issues
So prior to me taking my car up to Summit point for the weekend, the brakes felt GREAT. I'm using racing brake ET700s, Motul RBF600 and stainless steel lines, just put them on.
After leaving the track, i notice my pedal doesn't feel anywhere near as firm as it did prior to the track. It feels quite soft actually, much harder to modulate the pedal.
I notice if i pump the brake a little the pedal feels MUCH nicer, i'm thinking maybe theres some air in the system, even though i JUST flushed/bled the system...? Is this normal after a weekend of track use?
I have not had this issue before with any of my other cars that i track quite often.
Opinions?
-Joey
Old May 18, 2010 | 07:12 PM
dpigguy's Avatar
dpigguy
can't comment on the Vette as I have not had the issue but on my race bike it is not unusual for air to be trapped in the calipers even with bleeding and after a ride, the brakes definately feel soft. try to bleed the system again ensuring you do it in the right order, etc.
Old May 18, 2010 | 07:27 PM
LMB-C6's Avatar
LMB-C6
Hmmmm, that's a weird one. I would think that if it's due to air in the system it would have been there all along - running on the track shouldn't have made a difference.....unless there was moisture in the system that boiled during hard use....
Old May 18, 2010 | 11:44 PM
Kaldar's Avatar
Kaldar
Now when youre bleeding the brakes on the 2008 Z06, do you want to bleed the inside or outsider bleeders first?
Old May 19, 2010 | 08:17 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
On our C5, hard track use would wear the pads on a taper and cause a slightly soft pedal like you describe. Not sure if the C6 is similar.
Good luck!
Old May 20, 2010 | 09:51 PM
Kaldar's Avatar
Kaldar
Hmm... after a few days of driving around, the pedal feels quite nice again. I'll probably flush the system again anyways.
Old May 21, 2010 | 12:54 AM
drivinfast's Avatar
drivinfast
i put BBK on the C6 and it took bleeding thru both side bleeders to get all the air out
Old May 21, 2010 | 02:44 AM
longdaddy's Avatar
longdaddy
Good luck!
this would explain OP's symptoms. pumping the brake puts the pad in full contact with the rotor, then they go back and need to be "tilted" by the pistons to come back into full contact.
driving for a while starts to wear the pads normally again.
i would pull out the pads and check for taper, and if they are tapered swap them side-to-side
yeah this is normal after a track day
Old May 21, 2010 | 08:37 AM
Justasheet's Avatar
Justasheet
Check that the bleeders aren't leaking a little. Speed bleeders occaisonally will have this problem. Ask me how I know.
Jeff
To Brake issues
