glue
Old May 19, 2010 | 09:49 PM
randy ransome's Avatar
randy ransome
Winner 2020 C4 of the Year - Unmodified
2018 Corvette of Year
2017 C2 of Year Finalist
2015 C4 of Year
Default glue
what type glue or tape do you use for rearview mirror radar detector bracket? I tried double sided tape but when it got hot it would not hold.
Old May 19, 2010 | 10:09 PM
Epic_C6's Avatar
Epic_C6
Maybe get some rear view mirror glue from an auto parts store. If you never plan on removing the bracket this will definetly hold it.
Old May 20, 2010 | 01:29 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
How thick was the tape?
Autozone sells 3M double sided tape (really just a solid strip of adhesive) that's about 1/16" thick and available in a variety of widths.
Prep both surfaces by cleaning very thoroughly with alcohol (swabs/pads from the drugstore) and then apply an adhesion promoter (bondprousa.com/bondpak adhesion promoter pen) and let it set up.
Perform the above and attach the mount in warm weather only and let it set overnight.
The only caveat is that this is the one shortcoming of this type of mount. They've been known to fall off.
There is an arm type mount that clamps to the mirror stalk and places the detector in the same position as the stick on. But they're having growing pains as well.
Good Luck.
To glue
