First of all, don't worry. You can fix this. I had worse happen to my wife's jsb convertible when we went to Carmel, Ca last year. Acid rain actually etched the clear coat. I used my porter cable random orbital buffer and a 3m product called Finessit II. Buffed it with that and it helped. Waited a month or two and did it again and it all disappeared. You won't burn through the clear with a PC buffer. I used the pads from Adams, but others will work just as good. At least, yours is probably on the surface. Mine was etched into the clear.
