I'm starting to get a real launch from my car when downshifting into 4th and 3rd gears. When I say launch I mean the whole front of the car jumps and the thing is ready to launch. Now if I wanted to go go go its great but this is happening when I'm downshifting and coming to a light. I also get "Engine Drag Control Enabled" in my DIC.
Any reason for this, I read other posts on this message and I'm sure my tires are not slipping. However, I have new Vossen Wheels 19 fronts and 20's on the rear, would that cause issue with the computer??
ENGINE DRAG CONTROL ACTIVE
This message displays when engine drag control is
active. When driving in a lower gear in rainy, snowy,
or icy conditions and then letting up on the accelerator
or downshifting, the rear wheels may begin to slip and
this message displays. This message stays on for
a few seconds following the engine drag control event.
I'm in FL and its been nice all the time, no rain or anything on the roads and I wasn't even going all that fast, like 30-40mph.
Drag control is normally activated when the car thinks that the rear tires are rotating too slowly in relation to the fronts - it thinks that you have managed to get the rears sliding or losing traction (ice, snow, rain) as a result of your downshift. If you have larger diameter rears (or smaller fronts) the the car can get the wrong idea. There is nothing wrong with this. btw. It's the car doing a normal thing (unless yours is screwed up somehow.) The message is just to let you know that the low level surging you'll feel is the car doing its thing. It's an informative message and not a "get this fixed" message.
Z//
Thanks for the above, appreciate it. However, the issue that bothers me is the "lurching" or "surging" forward because it could be dangerous if the car jets forward and someone is near me in front, that is my concern.
The tires I have are bigger than stock, stock on a C6 is 18 fronts 19 rears, my wheels are 19s front and 20s rears. However, this just started happening a week or so ago. I've had the tires on for like a month+.
The car isn't going to "jet forward". What's happening is that the car is feeding a tiny bit of throttle into the system to try and get the rear tires to quit sliding. What you're feeling isn't acceleration. It's less deceleration. There is a difference. If you're following someone closely enough for this to cause you to hit them then I suggest that you're following them waaaaaay too closely
But this may be the first time that you have created the situation that caused the car to bring drag control into play. The wheel size is not the issue; it's the mathematical relationship between the front and rear tire diameters. That's the starting point for the computer's calculations.
Your choices are:
- get the front and rear tire relationship back in sync.
- drive the car with the traction control system off (or at least comp mode)
- get used to it
Experiment/practice with the car to learn when it happens so you know what to expect. If you learn how to make it happen at will you'll quickly realize that it's not really a big deal. Any brake or throttle input will cancel the drag control, btw.
My car has bigger rears and I get the drag control event every now and then - usually at higher rpm & speed. I can make it happen just be letting off the gas - no downshifts required. I just accept it as part of the car. Other folks have gone to a size bigger rears -and- a size bigger fronts which preserves the front/rear ratio.
No, usually RPM's are low and then I downshift but I do not rev the RPM's up beforehand. Never did and never had that happen.
Talked to my shop, might be something needed in the tune / computer.
If your not matching revs accurately on downshifts, that's a major problem. If you fail to do it in a corner you could lock the rears and crash the car. I would make sure you are matching accurately so that the momentum of the car is never being used to drag the rpm up after you go to the lower gear. You can do it with the clutch in, or ouble clutch and do it in neutral. If under braking, this involves heel-toe technique...
Your choices are:
- get used to it
Z//
the above is very interesting, and could the be the cause. and it could be the overall relationship of diameters is slightly different (or more than slightly) from stock and the computer is reading it occasionally under certain circumstances.
Unless there is actually something wrong with his car (which is probably not that case - but it could be) then it's probably the tire sizes. Faling to rev match could/would also bring it on. If I had to guess I'd say that tire size changes have brought the car closer to the threshold where drag control will activate and then the failure to rev match brings things over the threshhold - even at relatively low rpms and speeds.
There have been quite a few threads on this in the C6 Z06 forum. A search on "drag control" should present lots of good information on the topic.
That is what the brakes are for. You shouldn't be using the engine to slow the car in those situations. Brakes are much cheaper than replacing drive train parts or having an accident because you locked up the rear wheels when downshifting. Pull the fuse to the EBCM and try downshifting without drag control and see what happens then.
The tires I have are bigger than stock, stock on a C6 is 18 fronts 19 rears, my wheels are 19s front and 20s rears. However, this just started happening a week or so ago. I've had the tires on for like a month+. You may not hear the rear tires slipping when you downshift. It wouldn't take much slippage for feature to activate. With the possibility of the tire diameters getting the wheel speed differences closer to the point where the brake controller senses slippage and the added impact of abruptly downshifting causing an additional delta to the rear wheel speed the brake controller may well initiate drag control by requesting the PCM to increase throttle by a predetermined amount.
Guys, thank you so much for this input, I'm going to review this with my shop guys and I'll probably deal with it, never happens at high speeds but your right I probably will have to pay attention to the car closely and see if I can recreate when I want, which I have been doing.
My Tires are Pirelli P Nero Zero
275/30/19
305/30/20
The Pirelli's you have are not that far off from the OE diameters but slightly increase the likelihood of getting drag control.
Pirelli=== GY
F 25.6 === 25.7
R 27.2 === 26.9
