Scratch Repair
Old May 29, 2010 | 11:18 AM
ateam311's Avatar
ateam311
Default Scratch Repair
So, I've changed the oil, replaced the battery, RejeX'd the entire car, and now it's time to worry about this scratch:
It's not a deep scratch at all (can't really get my fingernail in it), but you can definitely feel it when you run your finger over it. Any advice on how to go about fixing it would be greatly appreciated
Old May 29, 2010 | 11:24 AM
Cybernetic Medic's Avatar
Cybernetic Medic
Ouch! From the looks of it in the picture, I think the only way to eliminate it would be to take it in to a body shop.
Old May 29, 2010 | 11:28 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Old May 29, 2010 | 11:38 AM
ateam311's Avatar
ateam311
Previous owner told me it likely occurred during the winter. I have a feeling it's the victim of a snow shovel
It's not a huge deal right now I suppose. I definitely don't want to go and drop $200-$300 just to fix a scratch. :o
Old May 29, 2010 | 11:40 AM
wysiwyg's Avatar
wysiwyg
If you do not want to drop the money to fix it, then I would try M105. I have been truly impressed how much correction I can achieve with M105 even by hand!
My son's car was keyed across the hood (from right to left across the width of the hood), and I used M105 and was able to remove about 90% (with the exception of the section which broke thru the paint) by HAND using M105. You can still see the "scratch" in the right lighting but it is hardly noticeable. It is definitely a huge improvement as it was VERY noticeable.
I did not want to spend money on my son's car since he was heading off to college where it will receive more damage so I decided to try M105 by hand to see what it could do.
I was impressed!
Old May 29, 2010 | 11:51 AM
ateam311's Avatar
ateam311
My son's car was keyed across the hood (from right to left across the width of the hood), and I used M105 by hand and was able to remove about 90% (with the exception of the section which broke thru the paint) by HAND using M105. You can still see the "scratch" in the right lighting but it is hardly noticeable. It is definitely a huge improvement as it was VERY noticeable.
I was impressed!
Very interesting indeed! Do you recall where you purchased it? I can get a bottle from Amazon but I wouldn't mind venturing out this weekend and trying to fix it.
Old May 29, 2010 | 11:56 AM
wysiwyg's Avatar
wysiwyg
I ordered it online from Autogeek (it was a sample size).
I am not sure where you could find it locally (although I have not tried finding it locally).
One other thing, on C6 clear coat you will probably need to follow up 105 with something less aggressive to remove the swirls M105 may introduce. I've used on my black C6 and had to follow up with a less aggressive polish to clean it up.
Old May 29, 2010 | 11:57 AM
Illinois427's Avatar
Illinois427
The pictures make it look like a pretty deep scratch, but if you can't hang your fingernail in it then it may not be as deep as it looks. If it isn't that deep, I would take it to a professional detailer and ask them to buff it out. A body shop might be willing to do that also. If you can hang your fingernail in it at all, you really need to look at a professional re-spray for it to be right. It looks like it is in a highly visible spot and it will stick out pretty bad if you touch it up.
Old May 29, 2010 | 12:13 PM
esfoad's Avatar
esfoad
Would wet sanding work on something like this? I once had a chaff mark from a sunroof deflector and was able to fix the marks with wet sanding. Gotta be careful, no pressure, let the sandpaper do the work.
Old May 29, 2010 | 12:45 PM
stockticker's Avatar
stockticker
yeah you can buff that right out.....
Old May 29, 2010 | 12:57 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Yup
I will do smaller scratches, even if they hang a fingernail, using the method I have seen on TV/Internet using standard GM touch up paint. Not perfect but hides them pretty well - to the point of unnoticable - and saves the body shop respray.
Old May 29, 2010 | 01:03 PM
hawkgfr's Avatar
hawkgfr
Wet sand with 2000....Sand till it is milky and dull but the scratch looks like is has disappeared the the haze......Buff with light compound then finish glaze with the PC...
It will make you week kneed at first but it works....(as long as it is in the clear and not to the primer.)
To Scratch Repair
