Attack Blue Filter
Old May 30, 2010 | 03:29 PM
Crossofiron's Avatar
Crossofiron
Default Attack Blue Filter
I just installed a Attack Blue filter. Very nice product but I did not get the 6 screws to replace the stock screws. The issue is that only 2 of the 6 stock screws are able to make contact with the base. I had to Mickey Mouse 2 screws to make a tight bond. My question is whether I should have got new screws? Anybody know? Thanks!
Old May 30, 2010 | 04:05 PM
TKO Performance's Avatar
TKO Performance
Premium Supporting Vendor
Active Streak: 90 Days
From: ★ Performance Parts & Accessories ★ 1800 778 9898
St. Jude Donor '07-'08-'11-'12-'13-'14-'15-'16-'17
The filter uses the stock torx screws. If only 2 screws are making contact, its because the filter is not seated properly and or all the way down. Push it down (hard) into the box. Place the front brace on. Screw down in a cross pattern (like lugs on a tire).
That will do it
__________________
Serving The Corvette Forum For 25 Years!!
Allow us to add you to the list of extremely satisfied customers.
Order Securely Online 24/7: http://tkoperformance.com/index.html
Feel Free To Contact Us By Phone: 1800 -778- 9898 Monday- Friday 9:00am to 4:30pm
Click Here: http://www.facebook.com/pages/TKO-Pe...e/367433626633
God Bless America!
Old May 30, 2010 | 04:08 PM
Crossofiron
Default Thanks
I had considered that but I typically do not force things into place without knowing the results.
Now I do!
Old May 30, 2010 | 04:10 PM
TKO Performance
Now I do!
No problem. You will find she will seal up real nice too when you do that...
Enjoy
Old May 30, 2010 | 05:49 PM
Crossofiron
Default Fits great
Enjoy
Thanks again. You are correct. It fits nicely. Only hard part was getting all the screws to set correct. The lug nut suggestion was very helpful. I noticed the pattern on the "lid" of the assembly. What is the real function of this plastic pattern? Does it break up the air flow?
I ask because it is very delicate and I broke one small arm duing the assembly. Do you think that is a problem?
To Attack Blue Filter
