Rev Limiter
THUS, any time you reach redline w/ the either nanny active, the only way to avoid the rev limiter is to back off the throttle.
Also, if you turn off TC or use Comp mode, there's a note in the owners manual that warns:
"Notice: When traction control is turned off, or
Competitive Driving Mode is active, it is possible to
lose traction. If you attempt to shift with the rear
wheels spinning with a loss of traction, it is possible
to cause damage to the transmission. Do not
attempt to shift when the rear wheels do not have
traction. Damage caused by misuse of the vehicle is
not covered. See your warranty book for additional
information."
...as well as this one...
"Notice: Fuel will shut off at about 6500 rpm for the
base model and 7000 rpm for the Z06 model. If you
continue to drive your vehicle at the fuel shut off rpm,
you could damage your engine. Be sure to operate
your vehicle below the fuel shut off rpm or reduce
your rpm quickly when the fuel shuts off."
, MIG
http://forums.corvetteforum.com/c6-c...g-problem.html
If temp and surface are not good enough you may still have traction problems even with newer, better, or wider tires.
I took me awhile to realize that even small changes in temp had a major effect on my traction. Night time with temps in the mid 60's, horrible wheelspin. Sunny day temp of 80, almost no traction problems.
So just because someone has the rev limits tuned out it does not necessarily indicate that the engine will be harmed.
