Factory GPS Functionality
I have never seen an error in the nav that wasn't user error. The nav is very good at doing exactly what you tell it to do. If you tell it you want to go to Bwoling Green and ignore the list and limits on input it has trying to help you spell it correctly, it will not find it. But if you tell it you want directions to get from Bowling Green to Nashville and set the region for Montana, it gives a surprisingly good Montana routing. Because I like the nav so much I have had several PMs from people who insist the nav can't find their location. Every one was easy to find if you have read Talon's sticky. Take the time to learn how to use it and you will love all the extra features it has over the less expensive units. Jump in the car and push a bunch of random selections and you can join the uneducated masses who hate it.
Don't reconsider. I didn't think I wanted the nav because I already had a Garmin. At the last minute I decided I would get it because it would be built in and not floating around the cockpit in hard turns. Best decision (other than NCM delivery) that I made. We spent about an hour going over various features of the nav at the NCM and I used it on my 300 mile drive home on country roads. The Garmin was on the console and, when they disagreed, I chose the factory nav instructions. It worked great and the Garmin was relegated to the glove compartment after that.
Until there is a touchscreen unit that works as intuitively, fast, and seamless as google maps on an i"Device", no one will be getting my money.
I bought the factory NAV because it was integrated into the whole system (Hud etc.). Talon90's tutorial helps a lot but the real problem is when you only use your Vette occasionally as I do, the interface is so archaic that you need to constantly look at the manual to do anything beyond the basics. The only issue I've had as far as accuracy is it wouldn't let me enter a well know street as a destination. I don't know if this would be a problem with other NAV's as I thought they all used the same data base.As a comparison, I just picked up an 07 BMW X5 which came with the factory NAV and although the interface is not the easiest to use, I was able to do use it without having to refer to the manual, something I have not been able to do in the Vette after 3 1/2 years.
Negative!
There are a bunch of EDUCATED masses out there, who have read Talon's great tutorial and still feel the GM Navi is junk! There are many of us who do not randomly push buttons, as you alluded to, and are as versed in its operation as you.
Please ask yourself just 1 question...why do I need Talon Book of Knowledge to use a Navi? Why was it necessary for Talon to take the time and effort to explain an instrument which should be intuitively obvious? My lowly Garmin, which blows away the GM Navi, didn't even come with a single page of instructions!
It is simple, user friendly, quick, clean graphics, clear and precise directions, easily adapts to alternate routes, doesn't need to have regional disks, doesn't need to have regions identified and is portable. I can be ANYWHERE in North America and it can find any location within seconds, without the need to localize it. And all for about $150 bucks! Also, the cost of updating the maps and POIs are just $100 for the lifetime of the Garmin as opposed to the $200 a year for the GM.
Hey, if you like the GM Navi, stick with it! Have a ball but please do not insult those of us who have taken the time and effort to learn the Navi and still think it is terrible. We are not uneducated masses.
For anyone thinking of buying the GM Navi for navigation, there are clearly better choices. For those who want the GM Navi for limited functionality but makes the dash look better and they feel the Navi is safer when it is built in, go for it!
Negative!
