Question:Mirror Compass
Old Jun 6, 2010 | 10:20 PM
ChefMark's Avatar
ChefMark
Default Question:Mirror Compass
The Mirror Compass is not working correctly. No matter which way I go it tell me I am going North. It could be NE or NW but never South. I drove about 400 miles due east. Has anyone ever had this happen?
Old Jun 6, 2010 | 10:31 PM
SinCityJets's Avatar
SinCityJets
You need to enter the proper region for your compass. It is in the manual under calibrating the mirror or something like that. You need to set up the proper region code.
CHad
Old Jun 6, 2010 | 10:35 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
There is a calibration procedure for the mirror compass, in the Owner manual.
The calibration is a different issue from setting the proper region.
Old Jun 6, 2010 | 10:48 PM
ChefMark's Avatar
ChefMark
CHad
SO if you drive out of your region you need to reset the region number?
Old Jun 6, 2010 | 10:50 PM
Vette5.5's Avatar
Vette5.5
I've installed a few of these auto dim/compass mirror's and the calibration proceedure usually involve's a few circle's in an open parking lot. My Vette's mirror pretty much act's like your's, when sitting for several month's. Haven't done the parking lot thing, but a long trip with lot's of directional change's usually does it.
Old Jun 6, 2010 | 11:14 PM
Vette_DD's Avatar
Vette_DD
Note: the compass calibration process and the compass variance process that's printed on pages 2-39 to 2-43 of the 2008 owner's manual has an error in it. Everywhere that it refers to the map light ON/OFF switch, it should say the Mirror auto dimming switch.
That error has been in the owner's manual since the 2005 edition. In addition, several of the pages in that section are repeated, again, in both the 2005 owner's manual and in the 2008 owner's manual. I'm guessing it's that way in all model year manuals.
Old Jun 6, 2010 | 11:17 PM
Bill Dearborn's Avatar
Bill Dearborn
CHad
That is for setting the declination or the change in magnetic north as you travel across the country. With only 8 directions indicated the compass doesn't have enough resolution to worry about a few degrees difference.
Bill
Old Jun 6, 2010 | 11:40 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
When I picked up my 2010 coupe from the Museum they drove it in circles several times to get the compass to 'get it's bearings' and set it up to give the proper compass indicator.
Old Mar 29, 2019 | 09:29 AM
stymie222's Avatar
stymie222
Default Compass mirror
Are there any electronic modifications needed, if I replace my manual night/day rear view mirror with an OEM one that includes the compass ?
I know that to get the OnStar working, I do need new electronics, but unsure on the compass and temperature only.
Old Mar 29, 2019 | 10:19 AM
thedperrys's Avatar
thedperrys
Just a thought, you don't happen to have a phone mount with a magnet installed anywhere close to the mirror do you?
Old Mar 29, 2019 | 10:46 AM
stymie222's Avatar
stymie222
Default Mirror/Compass
No Magnetic device at all
To Question:Mirror Compass
