nav disc copying
Old Jun 11, 2010 | 12:23 PM
z51vett's Avatar
z51vett
Default nav disc copying
Has anyone had any luck copying their nav disc
z51vett
Old Jun 11, 2010 | 12:26 PM
funymuny's Avatar
funymuny
I copied one for my Yukon to have as a backup. I tested it...it seemed to work fine. Probably should do the same for the Vette, just haven't.
Old Jun 11, 2010 | 12:50 PM
cclive's Avatar
cclive
I always use a copy in my Vert because the disc can be ejected when the car is parked. It works fine. I think that Verbatim DVD+R DL discs are the most reliable. There is no copy protection on the NAV discs, so copying is easy. I wouldn't care if I lost a $1 copy but if I lost a $200 original..............not good.
Old Jun 11, 2010 | 01:21 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Should work fine by using a program called "IMGburn" to both make the .iso out of the disc and then to burn it. Keep in mind you will need dual layer DVDrs (as cclive has mentioned, try to get Verbatim Singapore discs)
Old Jun 11, 2010 | 02:28 PM
PJRed2008's Avatar
PJRed2008
You don't need a special program. Nero and Roxio both work fine.
To nav disc copying
