I use a good car wash then dry with "absorber" Last step for me is the use of Meguiar's NXT wax which is a polymer type of wax vs Carnuba. Also use a microfiber cloth to remove the wax. If this does not work you might have to use a more abrasive coat prior to the use of NXT. Hope this helps.
Make a mix of 50/50 water and plain white vinegar in a spray bottle. Go over car with that to remove water marks. Then wash and wax (I use NXT too). That's it.
I have read several post that say to use water and vinegar. Not sure of the exact mixture but it does work, if no one else responds with more detail try a search.
Previous post got there while I was replying.
I have read several post that say to use water and vinegar. Not sure of the exact mixture but it does work, if no one else responds with more detail try and search.
Thanks for the reply's guys. It looks like I'll try the 50/50 water and vinegar route.
I can't get that to work. Is there some sort of secret trick? Water + vinegar in a spray bottle then I rub it around and dry it off. Did not work for me.
From: Stafford VA, home of our wolf den. No house break ins to date.
vinegar, wd40, and clr all work if the water spot is etched into the clear coat. Wet sanding will take it out when it's etched into the paint. good luck..
Originally Posted by Cobfree
Tried WD-40, water/vinegar, cleaners and nothing works. Has anyone tried bug/tar cleaner or Scratch-X?
I had some bad ones when I took delivery of my c6... the stubborn ones I finally removed with Zaino Fusion clear coat swirl remover.. did it by hand spot by spot.. pretty easy.
If you're going to use vinegar on your paint, be sure to wash it afterwards!! And preferably wax too, even if it just some of that quick detail stuff....
