Muffler Plate Question???
Old Jun 13, 2010 | 10:47 AM
tpawlak's Avatar
tpawlak
Default Muffler Plate Question???
I am installing a Muffler Plate and have a question for anyone who has installed one on their car. I asked my Dealer to move my mufflers up above the black plastic on either side of the mufflers. They said they raised the muffles as far they could go and now the mufflers are just about even with the black plastic on either side of the mufflers but still just a little under the black plastic. When I mount the muffler plate the back end of the plate can be even with the plastic but only if I force it up a bit. The back of the muffler plate is still catching the muffler but not as bad as before I had the mufflers raised. Before I had the mufflers raised I couldn't even for the plate up. I screwed the plate in with the 2 screws provided and the plate looks good and is flat against the plastic on both sides. My problem, well I am not sure it is a problem which is why I am asking, is that the underside of the plate is pressing against the mufflers. I drove around a couple miles and there are no rattles but I am concerned with the plate against the mufflers. My question is if this is normal or does the muffler need to be raised even higher somehow???
