automatics
Old Jun 16, 2010 | 11:12 AM
mrcc6's Avatar
mrcc6
Default automatics
Just wondering if it is ok to leave the transmission in sport mode and let the automatic do its thing , then when you want to just start using the paddles
Old Jun 16, 2010 | 11:27 AM
Davelt1coupe2010's Avatar
Davelt1coupe2010
That is what I do...but generally used the paddles 95% of the time.
Old Jun 16, 2010 | 11:28 AM
Josh_tampa's Avatar
Josh_tampa
I ALWAYS leave mine in Sport Mode and NEVER use the paddles. I hope it is okay to do that also
Old Jun 16, 2010 | 11:29 AM
evilmonkey's Avatar
evilmonkey
The only issue I've run into when driving in "S" mode without using the paddles is accidentally downshifting when not paying attention.
Old Jun 16, 2010 | 11:39 AM
Dif's Avatar
Dif
I always leave mine in "S" mode no problem.
The trans is noticable crisper in the "S' mode
Sometimes I use the paddles, sometimes not
Old Jun 16, 2010 | 11:41 AM
speedraider's Avatar
speedraider
same here, less slip in shifting
Old Jun 16, 2010 | 01:14 PM
NYC6's Avatar
NYC6
I do the same, you're not hurting anything.
Old Jun 16, 2010 | 03:32 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
My 06 has been in "S" mode since new.
Old Jun 16, 2010 | 03:55 PM
TheGlods's Avatar
TheGlods
I tend to keep it in sport mode and use the paddles.
Old Jun 16, 2010 | 03:59 PM
baxterboy's Avatar
baxterboy
"S" mode for me as well. It is programmed to hold the shifts longer. When I got my car dyno tuned he had it in "S" mode as well. I never use the paddle shifters.
Old Jun 16, 2010 | 04:41 PM
Migs08's Avatar
Migs08
I like using the paddles, and have adopted some "paddle-isms":
1. I don't always paddle downshift when slowing down, but I always paddle downshift as it comes to a complete stop so I'm starting again in 1st versus 2nd.
2. After upshifting to cruising speed, if maintaining a constant speed for awhile, I usually bump it to "D" then back to "S".
3. I like to keep it in paddle mode when driving on twisties, so I can keep the tach up around 3000rpm for better throttle response.
There's definitely some finesse involved in using the paddles effectively, IMHO.
Old Jun 16, 2010 | 06:41 PM
rz2mbc's Avatar
rz2mbc
Default Paddle-isms
1. I don't always paddle downshift when slowing down, but I always paddle downshift once I'm at a complete stop so I'm starting again in 1st versus 2nd.
Paddle-isms....new word for Mr. Webster & spell check...neat
Agree with comments.
Old Jun 16, 2010 | 06:53 PM
lastcowboy's Avatar
lastcowboy
more gas....but OK.
To automatics
