Diff Questions
Old Jun 17, 2010 | 09:32 PM
Mike Green9's Avatar
Mike Green9
Default Diff Questions
Does anyone know the size of the allen key used to check/drain the diff? It appears to be slightly larger than 3/8"
Also, when did GM realize that the axle nuts were not torqued correctly at the factory, and hopefully rectified the situation?
Thanks,
M...
Old Jun 17, 2010 | 10:23 PM
RicK T's Avatar
RicK T
Originally Posted by Mike Green9
Does anyone know the size of the allen key used to check/drain the diff? It appears to be slightly larger than 3/8". Thanks,
M...
10mm
I'm pretty sure it's covered in this DIY.
http://forums.corvetteforum.com/c6-c...s-for-faq.html
Old Jun 18, 2010 | 09:02 AM
Mike Green9
Great info.
Thanks,
M....
Old Jun 18, 2010 | 10:43 AM
LS WON's Avatar
LS WON
Originally Posted by RicK T
10mm
To Diff Questions
