Can Anyone help me decode this GMVIS?
Wondering if any of the night owls can help me out here. Member GMAutotech was gracious enough to PM me a GMVIS report earlier but now that I have it, I'm a little unclear on how to interpret it. Some of the things I'm reading have me worried, it looks like a lot of stuff has been replaced including fenders and headlamps and a muffler... is that right?
What do you guys get out of this? Thanks for any help!
Model: 1YY87-2006 CORVETTE Z06 2 DOOR
Service Contract: No Branded Title: No Warranty Block: No PDI Status: No
Order Type: 60 - RETAIL - SOLD
Field Actions: 0 Open
Required Field Actions Open field actions are highlighted
Type Number Original Nbr Description Release Date Status
Customer Satisfaction Program N050112 05112 PAINTED ROOF ADHESIVE SEPARATION 02/20/2006 Closed
Customer Satisfaction Program N060092 06092 OWNER MANUAL UPDATE - BRAKE WEAR- ** EXPIRES DECEMBER 31, 2006 ** 10/10/2006 Closed
Branded Title
*The VIN information contained herein and information derived therefrom is the proprietary property of The Polk Company and is to be used only for the purpose of warranty verification and shall not be used for any other purpose whatsoever.
Vehicle has no current record of branded titles.
Warranty Block
Vehicle has no current record of warranty block.
Service Information
Vehicle has no current record of outstanding service information.
OnStar and XM Satellite Radio Information
Refer to Help page for details. For OnStar contact 888.ON.STAR1 (888.667.8271) and for XM Radio contact 877.GET.XMST (877.438.9677).
OnStar Equipped: N OnStar Status: NA
XM Equipped: Y XM Radio ID: LRTGG00W XM Status: Inactive
OnStar Vehicle Diagnostics: N DMN Enabled: N
Applicable Warranties Valid warranties are highlighted
Valid Description Start Date Effective Odometer End Date End Odometer
Bumper to Bumper Limited Warranty 02/10/2006 21 MI 02/10/2009 36,021 MI
Emission Select Component Ltd Wty 02/10/2006 21 MI 02/10/2014 80,021 MI
Corrosion Limited Warranty 02/10/2006 21 MI 02/10/2012 100,021 MI
Service Contract
Vehicle has no current record of service contracts.
Transaction History View Details
Job Card Date Job Card Number Transaction Type Transaction Adjustment Labour Operation Odometer Reading
01/14/2009 244713 ZREG----Regular Vehicle Transaction L2591 - Muffler - Dual - Left - Replace 8,531 MI
12/04/2008 242861 ZREG----Regular Vehicle Transaction B7289 - Headlamp/Composite Assembly - Left - Replace 7,960 MI
12/04/2008 242861 ZREG----Regular Vehicle Transaction B7288 - Headlamp/Composite Assembly - Right - Replace 7,960 MI
09/08/2008 X81403 ZREG----Regular Vehicle Transaction Z2080 - ROADSIDE SERVICE (TOWING) 7,500 MI
09/08/2008 238834 ZREG----Regular Vehicle Transaction K0600 - Cylinder, Actuator Clutch Master - R&R Or Replace 7,811 MI
09/08/2008 238834 ZREG----Regular Vehicle Transaction K0620 - Cylinder, Clutch Actuator - R&R Or Replace 7,811 MI
09/08/2008 238834 ZREG----Regular Vehicle Transaction B4150 - Outside Rearview Mirror Glass Replacement - Right Side 7,811 MI
09/08/2008 238834 ZREG----Regular Vehicle Transaction C1421 - Weatherstrip, Hatch Or Front Roof Panel - Left - Replace 7,811 MI
09/08/2008 238834 ZREG----Regular Vehicle Transaction C4218 - Front Floor Panel Carpet Hook Replacement 7,811 MI
09/08/2008 238834 ZREG----Regular Vehicle Transaction C4219 - Retainer, Floor Mat - Left - Replace 7,811 MI
09/08/2008 238834 ZREG----Regular Vehicle Transaction S0281 - Fender, Front - Left - Replace 7,811 MI
09/08/2008 238834 ZREG----Regular Vehicle Transaction S0280 - Front Fender Replacement 7,811 MI
09/08/2008 238834 ZREG----Regular Vehicle Transaction J3220 - Radiator Air Lower Seal Replacement 7,811 MI
05/20/2008 233555 ZREG----Regular Vehicle Transaction F9709 - Drain and Refill Rear Axle Fluid 7,751 MI
07/12/2007 216172 ZREG----Regular Vehicle Transaction Z7091 - NON-WARRANTY INCREMENTAL EXPENSE/WHOLESALE 3,885 MI
04/10/2007 211864 ZREG----Regular Vehicle Transaction F2006 - Cover And/Or Gasket, Differential - Rear Differential - Rear - Replace 4,986 MI
10/24/2006 203577 ZREG----Regular Vehicle Transaction Z7907 - COURTESY TRANSPORTATION - PARTS NOT AVAILABLE 3,883 MI
10/24/2006 203577 ZFAT----Field Action Recall V1495 - 06041- Inspect and Replace Roof (inc. 1.5 hrs for paint and mix time) 3,883 MI
08/01/2006 199451 ZFAT----Field Action Recall V1482 - 05112 - Inspect and Replace Roof Panel and Headliner (includes 1.5 hrs. for paint and mix time) 3,045 MI
07/26/2006 199109 ZREG----Regular Vehicle Transaction E7690 - Sensor, Steering Wheel Rotation - Replace 3,015 MI
06/19/2006 197337 ZFAT----Field Action Recall V1482 - 05112 - Inspect and Replace Roof Panel and Headliner (includes 1.5 hrs. for paint and mix time) 2,842 MI
06/19/2006 197337 ZREG----Regular Vehicle Transaction C2860 - Front Floor Console Replacement 2,842 MI
06/19/2006 197337 ZREG----Regular Vehicle Transaction C4219 - Retainer, Floor Mat - Left - Replace 2,842 MI
06/19/2006 197337 ZREG----Regular Vehicle Transaction Z7906 - 6+ DAY COURTESY TRANSPORTATION 2,842 MI
06/13/2006 D86009 ZREG----Regular Vehicle Transaction Z2083 - ROADSIDE SERVICE (BATTERY/JUMP START) 2,500 MI
01/27/2006 A16312 ZPDI----Pre-Delivery Inspection Z7000 - Pre-Delivery Inspection - Base Time 0 M
Vehicle Build
Model: 1YY87-2006 CORVETTE Z06 2 DOOR Order Number: JMNTBW
Gross Vehicle Weight: 1,633 Build Date: 01/27/2006
Build Plant: 5-
Option Codes
*GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
193 - EBONY 19I - BLACK INTERIOR TRIM
19U - LEMANS BLUE 1SZ - PREFERRED EQUIPMENT SAVINGS
2LZ - 2LZ PREFERRED EQUIPMENT GROUP UNIVERSAL HOME REMOTE MEMORY PACKAGE AUTO DIMMING ISRV MIRROR W/COMPASS & DRIVER OSRV MIRROR HEATED SEATS RDS AM/FM STEREO W/6-DISC IN DASH CD W/MP3 PLAYBACK, BOSE PREMIUM 7 SPEAKER SYSTEM XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL. (REPLACES STD/OPT/PKG RADIO) PWR TELESCOPING STEERING WHEEL AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER LUGGAGE SHADE & PARCEL NET AAB - MEMORY PACKAGE
AJ7 - AIR BAGS, FRONTAL & SIDE IMPACT, DRIVER & PASSENGER AQ9 - ADJUSTABLE SPORT BUCKET SEATS WITH LEATHER TRIMMED SEATING SURFACES
BGR - BOWLING GREEN PLANT CJ2 - AIR CONDITIONING-ELECTRONIC DUAL ZONE
D42 - LUGGAGE SHADE & PARCEL NET DD0 - ELECTROCHROMIC MIRRORS INSIDE REAR & LEFT OUTSIDE REAR
DD8 - OSRV DL5 - ROADSIDE SERVICE INFORMATION DECAL
E2C - ORDER TO DELIVERY - EXPEDITE FE4 - Z06 SUSPENSION
FE9 - 50-STATE EMISSIONS GU6 - REAR AXLE 3.42 RATIO
IL3 - TRIM INTERIOR DESIGN-AQ9 J56 - BRAKE SYSTEM POWER
JL5 - CONTROL MANUAL TRANS, 1ST TO 4TH GEAR SKIP SHIFT K63 - 110 AMP GENERATOR
KA1 - HEATED SEATS LS7 - 7.0 LITER SFI V8 - 505 HP
MM6 - 6-SPEED MANUAL TRANSMISSION MN6 - 6-SPEED MANUAL TRANSMISSION
N37 - STEERING: POWER TELESCOPING& MANUAL TILT STEERING COLUMN NK4 - LEATHER WRAPPED STEERING WHEEL
NT9 - FED EMIS SYS, TIER 2 PHASE-OUT Q10 - SILVER PAINTED ALUMINUM WHEELS
R6P - PREMIUM PAINT R8K - *******************************
R9N - LEATHER SEAT TRIM R9Z - POMS EXPEDITE - SOLD ORDERS
SLL - SOLD ORDERS U2K - XM SATELLITE RADIO - SERVICE FEE EXTRA. 1ST 3 MONTHS INCL.
U3U - AM/FM CD WITH DVD NAVIGATION, INCLUDES TWO FREE MAP UPDATES (REPLACES 6-DISC IN DASH CD W/SINGLE DISC CD) U52 - ELECTRONIC INSTRUMENTATION
U65 - SPEAKER SYSTEM 7, PREMIUM UG1 - UNIVERSAL HOME REMOTE
UJ9 - LOW TIRE PRESS. INDICATOR US3 - ANTENNA DIVERSITY
V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA VDD - VEHICLE INFORMATION DVD
XFA - FRONT TIRE - P275/35ZR18 YFJ - TIRE REAR P325/30ZR19 BW
When I was a service manager for a "foreign" car manufacturer, we had a customer want us to warranty the flood damage from the son's mistake of opening the door on a car that was sitting in 3' of water-solely because he bought so many cars from the dealership. There were a couple of people that "thought" about doing it! Finally common sense won out.
I'd run...not walk from this car. As someone else stated...you are going to try to sell this car at some point and someone else is going to have the same thoughts as you. This car is either a poorly constructed example of a Corvette or there is something fishy with the warranty work as I can't imagine a single car having that many warranty concerns...it just isn't statistically realistic.
They dealt with the roof panel delamination (twice).
They had a problem with a dead battery and looks like they kept the car for six days for diagnostics.
They have a problem with floor mat retaining hooks, replaced multiple times.
They replaced the steering wheel position sensor, possibly in response to what is now the service active handling recall, or simply because it needed replacing.
They replaced the differential fluid, probably for a noisy rear end.
The entries at 9/08/2008 7,811 raise a few questions and appear that the car was either side swipped, in an accident or scraped the side of a garage coming in or going out. The vehicle was towed and they replaced left side roof weather stripping, left side mirror, left front inner fender, left front fender and the radiator air lower seal. However, no front fascia or bumper components. They also replaced the clutch master cylinder, perhaps could have been what prompted the physical repairs as it is for the same date stamp and mileage as the body repairs above.
They replaced both headlight assemblies which could have been due to crazing or damage to the lens which must not have been attributable to the owner. Since they are not on the same date stamp or mileage as the physical repairs I wouldn't think that they are accident related.
They replaced the left side NPP muffler.
Here's the car I was looking at:
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6168
Everything else on it seemed to check out and I was just about ready to put a deposit on this too. But I think I am with you folks... there is a risk with this car that doesn't really need to be there.
Anyone have a LMB Z06 for sale?
