Coolant temp question?????
Old Jun 20, 2010 | 02:13 PM
07blkvette's Avatar
07blkvette
Default Coolant temp question?????
I was on the interstate crusing at 70 with a/c on. Noticed my temp was at 203-208 turned a/c off and it went back down to 183-187. I have a SC
but also have the 160 stat. Is this normal? I can remember when I used to turn the a/c on and it used to make the temp go down.
Old Jun 20, 2010 | 02:25 PM
cthusker's Avatar
cthusker
Well within normal range IMO. Yes.. turning on the A/C will lower temps on these cars. Mine runs about 188 to 185 cruising with temps in 70's to 80's... it will jump higher on really hot days. I also have a 160 stat....
Old Jun 20, 2010 | 02:31 PM
johnodrake's Avatar
johnodrake
Moderator
Seems odd that the A/C would cause that much of a rise in temps..... Normally it has very little effect.
To Coolant temp question?????
