Window Scratch
Old Jun 21, 2010 | 04:33 PM
kr51's Avatar
kr51
Default Window Scratch
I am so mad at myself... washed the 2010 GS Saturday and did not take my watch off. As I was cleaning the inside of the windshield, apparently my watch hit the window and put a 6" long minor scratch on the drivers side about 5" from the side frame. It appears to not be a deep scratch but certain light situations causes it to look larger than it is. Has anyone used window scratch removal products before? If so, please give me some helful hints.
Old Jun 21, 2010 | 07:19 PM
teuhl's Avatar
teuhl
This is a result from Googling:
You must be very careful handling scratches on your windshield. The windows in our car are made out of a material called “Safety Glass”. Upon impact the windows are made to crumb together instead of cracking into thousands of pieces. The minor scratch you have on your window has the possibility of suddenly shattering the window right in front your face! You are advised to use extra caution when cleaning or removing scratches from your car windows.
You can buy expensive glass scratch remove kits that sometimes have limited effects. In my experience nothing beats the recipe below, and it never hurts to save a few bucks here and there.
The first ingredient in our compound for your scratched and hazed window is a product called Jewelers Rouge. It is a mixture of aluminum oxide and wax; it is often used with buffing wheels, or to polish other types of metals. It commonly comes in a bar-like shape.
Jewelers caution when buying Jewelers Rouge, to only purchase Rouge that is red. Jewelers Rouge is made with ferric oxide, which gives it the red coloring. Rouge is French for red, so white Jewelers Rouge doesn’t make much sense. This product can very easily be purchased online; just stay away from the Rouges that aren’t red.
The next ingredient is called “Glycerin”. This product can commonly be purchased in any Drug Store. It is basically humectants, which attracts moisture to your skin. It is often included in soaps, and lotions.
The third ingredient is water. Regular tap water is ok, as long as it doesn’t have a high mineral count.
Now before we apply the compound, we need to make sure the glass is clean. First, clean the glass with a cleanser. I do not recommend ammonia cleaners; preferably use a citric acid or alcohol based cleanser. Then wipe away the cleanser. Soft terry clothes are best for initial soaking and wiping. When the cleaning is complete, carefully examine the window to ensure there is no dirt or grime near the scratch.
Now that the window is clean and we have our materials together. We can begin to make the compound.
Window Scratch Remover
2 Tablespoons Glycerin
2 Tablespoons Jeweler's Rouge
2 Tablespoons Water
First mix the ingredients in a small bowl, or container. The compound must be mixed very vigorously. Once the compound is mixed, place some on the starched area and rub gently. Please remember pushing too hard can shatter the whole window, so caution is advised.
Once the compound is applied, allow to dry for 20-30 seconds. After the compound has dried, use mild soapy water to clean off. If the scratch is very deep, you might have to repeat the instructions a few times.
Old Jun 21, 2010 | 08:11 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
No guarantees, but it's possible that your "scratch" is actually material from your watch that got rubbed off onto the W/S. Glass is harder than most watches, unless you have diamonds or something similar in the case.
You could try a very mild abrasive (I've used toothpaste but not sure that's very good) and see if that removes the mark.
Good luck!
Old Jun 21, 2010 | 08:35 PM
baxterboy's Avatar
baxterboy
I put some self inflicted scratches on the outside of my window trying to get some stupid stickers off. I was using a putty knife. I tried about 4 different products with no luck. Good luck, I know how annoying it is. Most people would never see it but you know it is there.
To Window Scratch
