Map Lamp Removal
Old Jun 25, 2010 | 04:23 PM
jackcasa's Avatar
jackcasa
Default Map Lamp Removal
Does this require a special tool? I can't get my fingers in the recess to pull on or twist the OEM bulb(s). And I have skinny fingers.
Old Jun 25, 2010 | 04:31 PM
Whisky's Avatar
Whisky
Get yourself a few small plastic zip ties. Fold one over and make a loop about the same diameter as the bulb. Push the loop over the bulb and tighten the zip tie. Give the end a slight tug and the bulb will pop right out!!
Old Jun 25, 2010 | 04:36 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
Or dental floss/string & pull don't twist
Old Jun 25, 2010 | 05:49 PM
jackcasa's Avatar
jackcasa
Cool! Thanks, guys.
To Map Lamp Removal
