C6 Insulation Kit Sale: 20% Off!!!
Former Vendor
Last day - C6 Insulation Kit Sale: 20% Off!!!
Thanks everyone for their orders!! ALL ORDERS HAVE SHIPPED, and most everyone should have received their kit by now.
Now, I wanted to announce a special sale we have running now through July 15th, (changed to July 18th) in conjunction with our return and the great response we have had from the Bloomington Gold Show.
In celebration of our success at Bloomington Gold, we have decided to run a "MADVETTE BLOOMINGTON GOLD SALE".
The sale is for the C6 Insulation Kits, and it is 20% off.
The MadVette C6 Pre-cut Insulation kit comes with everything you need to insulate (no more worries about baking items in your center console) and provide sound deadening in your Corvette, including Pre-cut pieces for your doors.
Other kits on the market provide a similar product, but do not provide pre-cut pieces for your doors, which allow road noise to be present in your front cabin. Our kit gives you everything you need to COMPLETELY insulate your C6 Corvette.
Our kit is a non-fiberglass, non-asphalt based product which weighs in at 3.5 lbs., for those who are weight conscious, it rejects 97% of the radiant heat, and knocks off 19db of sound and road noise!!!
It is only 3/16" thick, so as not to interfere with proper mounting of your panels and seats, and all holes are pre-cut & clearly labeled for your convenience.
It is our #1 goal to provide you ease of install, while making a HUGE improvement in your overall enjoyment of your Corvette!!! A must if you have an aftermarket exhaust and/or headers.
Each kit is hand cut to our specifications, and guaranteed to make a dramatic difference in your C6!!!
This applies to every order placed from 8pm CST Thurs. July 1, 2010 thru Thurs. July 18 at 12 midnight CST.
All items will ship beginning Friday, July 2nd, and will ship through the next 2 weeks, in the order which they were placed.
CLICK HERE TO ORDER.
Here are some pictures showing how to use the coupon code "bloomington":
Original Price
INSERT COUPON CODE "bloomington" and HIT APPLY
THIS SALE IS GOOD THROUGH 12 MIDNIGHT ON July 18th, 2010!!! COUPON CODE WILL NOT BE VALID AFTER THAT TIME!!
THANKS FOR YOUR SUPPORT!!!
2010 Bloomington Gold Pricing
Original Price
Former Vendor
Evening bump.....
Now, I wanted to announce a special sale we have running now through July 15th, in conjunction with our return and the great response we have had from the Bloomington Gold Show.
This applies to every order placed from 8pm CST Thurs. July 1, 2010 thru Thurs. July 15 at 12 midnight CST.
Original Price
THIS SALE IS GOOD THROUGH 12 MIDNIGHT ON July 15th, 2010!!! COUPON CODE WILL NOT BE VALID AFTER THAT TIME!!
Original Price
Said this before and I'll say it again. I don't believe for a second your product reduces interior cabin noise that much. Show me some test results. I do believe that it might make the car somewhat quieter but 19db, no way. 20db is a factor of 10 you're telling me your product makes the car 10 times quieter?
I don't know the exact noise reduction, but after my insulation install, my wife stopped complaining about the exhaust sound from the headers and Corsa Xtremes I have, which, btw, is music to my ears. For her to say that she was finally able to enjoy riding in the car again is good enough for me.
A lot of folks point out how hot the center console gets. I never thought it really got terribly hot, but the console is cooler with the insulation also.
All I can recommend is, since it is not a very expensive mod to begin with, even a small improvement in noise reduction and heat/cold insulation is well worth it.
Former Vendor
I've said it before as well, and will say it again here (since you brought it up again...) The 19db is the IRAM certification test results the manufacturer did with 1 layer of material at 50hz. My customers have driven in from out of state, with a decibel meter, and after installing the kit, measured a 10-11 db drop in their Corvette.
The only way you will know the proof is to order it, and if you don't like it, rip it back out, send it back, and I will give you your money back. The proof is in the pudding, as they say... Simple as that.
It makes a huge difference in the road noise, virtually eliminates the drone from an aftermarket exhaust, and combined with other material such as Dynamat, Second Skin, or Hushmat, the noise level is dropped even more. The heat is cut down quite substantially as well, and makes a huge difference in the overall cooling of the car.
Former Vendor
Also, here is a picture of the material, as well as the manufacturer specs on the material. Hope this helps answer any questions you have:
It has 5 layers, and though it is rated at a 19db drop in noise, I have tested it in the Vettes at 8-11 db. reduction. Here are some manufacturer specs on it:
Characteristics | Value | Regulation
Cell Structure: Closed
Nominal Thickness: 5 mm (+ or - 0.5mm)
Steam Permeability: 0.033 gr/m2hkPa ASTM E-96
Noise Insulation: 19dBA IRAM 4063 at 50hz
Flame Spread Index/Class: 25 or less/ "A" - Class 1 0 ASTM E-84
Smoke Index/Class: 450 or less/ "A" - Class 1 15 ASTM E-84
INSULATION LAYERS
Aluminum Foil
polyethylene backing
closed-cell Polyethylene foam
Aluminum Foil
Hope this helps.
Aluminum Foil
Former Vendor
Morning bump...
Original Price
Original Price
Former Vendor
Thank you
Thanks everyone for all the orders so far!
The response has been great....
Original Price
Original Price
Just placed my order. I have been thinking about this mod for quite some time, but a little apprehensive about taking apart the interior. I would like to reduce both the heat and the road noise and finally thought what the heck and will give it a try.....
Former Vendor
If you're in the area, we can do the install.
Tim
Former Vendor
Former Vendor
But, no, $300.00 is not in the ballpark. Price is $185.00 and take another 20% off (using coupon code "bloomington") for a discounted price of $148.00 plus shipping.
You can order at http://cca.madvettemotorsports.com/s...ct_detail&p=99
Tim
3 weeks ago I had Madvette Motorsports insulation kit installed and it most definitely eliminated the reverberation I was getting from my Basanni Exhaust system. I still hear the exhaust (which I like) but dont get the reverberation inside like before.
Former Vendor
Former Vendor
Morning bump...
Original Price
Original Price
