Power Vert Top Problem...and Solution
Tonneau Actuator Latch PN
The local dealer just fixed my 2009 tonneau for $602! They charged me $414.78 for the part. Part name is "AC Delco Actuator pn25809368". I found out afterwards that Walmart has the same part for $155, and $189 at Frugalmechanic.com
Just in case anyone has this problem. My Vert power top was getting jammed with the tonneau cover. The tonneau cover would lift and then drop back to the point where the roof would jam because it was catching on the tonneau cover. Well after taking it to the dealer, and about $350, they ended up replacing the tonneau cover latch which I guess has a sensor that tells the tonneau cover when to raise and when to lower. So if any of you has a problem with this and you dont want to take it to the dealer you may look in to that first. Just thought this might help.
owc6 (11-25-2015)
Yup, same with mine ^^^
But I don't stop the mechanism; I just pull the top forward so the tonneau clears and it hasn't caught my fingers once. Just part of my daily ritual.
Mine just started doing this.
I'm obviously out of warranty, and spending a bunch of money on a car that isn't worth much now, and even less tomorrow, seems silly. I just pull the window away from the tonneau when closing.
Problem solved.
Problem solved.
