noob request
Old Jul 3, 2010 | 11:32 AM
Tom's_03SVT's Avatar
Tom's_03SVT
Default noob request
Could someone please post pictures of a properly installed luggage shade. I think I have in there correctly, but I want to make sure (there werent any directions in the package). Additionally, any info on where I can get a decent body paint matched rear license plate for less than $100 would be helpful...
Thanks.
Tom
Old Jul 3, 2010 | 12:02 PM
mpuzach's Avatar
mpuzach
Here's one from Southern Car Parts. It's even on sale. It's the one I have (see my sig pic).
http://www.southerncarparts.com/corv...ame-p-651.html
Old Jul 3, 2010 | 12:29 PM
Tom's_03SVT
Great thanks!
Old Jul 3, 2010 | 12:47 PM
Duke/Earl's Avatar
Duke/Earl
Sunshade installation. I also clip the front flap back, to keep it from flapping in the breeze when the windows are open. The trunk divider, in my car, comes from Southern Car Parts.
Old Jul 3, 2010 | 12:54 PM
Tom's_03SVT
Thanks I was wondering about the third loop that goes over the trunk latch. Thanks for the help guys.
Old Jul 3, 2010 | 01:05 PM
mpuzach's Avatar
mpuzach
I also have the divider from SCP. It's a great accessory - a must-have for any coupe/Z06/ZR1 owner.
Old Jul 3, 2010 | 01:19 PM
TexasMadMan's Avatar
TexasMadMan
Concerning the plate frame, I'm pretty sure that is the one I have. If it is, be advised you will not be able to get in the back with the key unless you take the frame off. Don't know how important that would be to you. I carry the allen wrench in my billfold.
Old Jul 3, 2010 | 01:50 PM
Tom's_03SVT
Does your 2007 have the rear push button for the trunk release or just the lever and key hole?
Tom
Old Jul 3, 2010 | 02:01 PM
mpuzach's Avatar
mpuzach
Tom
All C6s have both. I believe his point was that in the event of a battery failure or fob locked in the trunk (circumstances when you'd have to use the key), the frame would have to be removed in order to get the key into the slot. FWIW, I just tried it and had no problem.
Old Jul 3, 2010 | 02:03 PM
Tom's_03SVT
Gotcha, I'm still learning all my C6 model facts...lol. Steep learning curve
Old Jul 3, 2010 | 02:55 PM
TexasMadMan
Yes, my car has both. mpuzach is correct. If you have to use the key to get in the back, then some frames have to be removed. I have one like you are looking at that uses the metal backing plate. The frames that use the original screw holes for the plate do not need to be removed. That's why I carry the allen wrench in my billfold. I have had to remove the frame once. No big deal to me, just pointing it out so you would be aware.
edit: since mpuzach said his works fine, then my information may not apply. Let us know if you get it.
To noob request
