outside temperature
Old Jul 6, 2010 | 05:38 PM
cobraduke's Avatar
cobraduke
Default outside temperature
The outside temp gauge seems to be stuck and I cannot find anything in the owners manual to re-set it. Can anyone help?
Old Jul 6, 2010 | 05:44 PM
Epic_C6's Avatar
Epic_C6
Mine does the same thing. Sometimes it will stay stuck on a certain temp for an hour or more. It will be obviously warmer or colder outside but it wont register correctly. Then for no reason it will just start working again. Never have been able to figure it out.
Old Jul 6, 2010 | 05:47 PM
JJC5's Avatar
JJC5
The owners manual explains it. Basically, you have to be at 30 or so MPH for a certain amount of time to get the outside temp to reset itself. If you're in stop and go traffic, it won't update.
Old Jul 6, 2010 | 05:50 PM
Bill Dearborn's Avatar
Bill Dearborn
Bill
Old Jul 6, 2010 | 06:07 PM
CO Lightfoot's Avatar
CO Lightfoot
The owners manual explains it...
"...There is a sensor located behind the front bumper.
This sensor reads the outside air temperature and
helps to maintain the temperature inside the vehicle.
Any cover on the front of the vehicle could give a
false reading in the temperature.
If the outside temperature goes up, the displayed
temperature will not change until:
• The vehicle’s speed is above 12 mph (19 km/h) for
five minutes.
• The vehicle’s speed is above 32 mph (52 km/h) for
two and a half minutes.
These delays prevent false readings. If the temperature
goes down, the outside temperature will be shown
when you start the vehicle. If it has been turned off for
less than three hours, the temperature will be recalled
from the previous vehicle operation."
The above is from pg 3-29 in the 2009 owners manual: http://www.gmpartshouse.com/download...09corvette.pdf
Old Jul 6, 2010 | 06:10 PM
Vette_DD's Avatar
Vette_DD
To update the outside temperature immediately, push the following 3 buttons on the A/C controls simultaneously:
fan speed, windshield defrost, rear window defrost.
This sequence is NOT in the manual, AFAIK.
Old Jul 6, 2010 | 06:33 PM
Epic_C6's Avatar
Epic_C6
Does that really work?
Old Jul 6, 2010 | 06:44 PM
jgauger's Avatar
jgauger
Default temp sensor
Yes, it works. I'll tell you something my gm friend to me about this subject. Our o/s temp sensor failed and it would read waaay to high, like 120 degrees when it was only 90 outside. I made the comment to him that it was not a big deal if it didn't get fixed. I mean, you know, we lived without those thing for years and years. He said, well, it might be a big deal. If it had failed on the low side and registered below 50 degrees your A/C wouldn't work. Needless to say, I got busy and changed it that day.
Old Jul 6, 2010 | 06:48 PM
LS WON's Avatar
LS WON
But when you do this the temp is unusally higher then it goes down real fast. Is this the temp of when car is sitting or of engine compartment?
Using the 3 buttons at the same time is representative of what temperature?
Old Jul 6, 2010 | 08:33 PM
Epic_C6's Avatar
Epic_C6
Cool, thanks for the info. It will come in handy.
That would suck if the A/C would not work because of the temp sensor.
Old Jul 6, 2010 | 09:24 PM
Vette_DD's Avatar
Vette_DD
It's the actual temperature that the sensor under the hood near the radiator is reading. It's the temperature you usually will see in the middle of the climate control window. Granted, it will probably go down once the car has been driven enough to cool things off in that area under the hood.
Old Jul 7, 2010 | 12:30 AM
LS WON's Avatar
LS WON
So that would be more engine heat than the aptmosphere?
Old Jul 7, 2010 | 12:56 AM
Vette_DD's Avatar
Vette_DD
Only if the car is sitting still, since the sensor is in front of the engine and the radiator.
Old Jul 7, 2010 | 01:00 AM
cclive's Avatar
cclive
Yup, that's why the system is set to delay until the car has been moving for a while. Push and hold the first, second and fourth buttons from the right simultaneously and you get the actual sensor temp immediately. On a hot day after driving, that could be very much higher than the outside temp.
Old Jul 7, 2010 | 01:46 AM
LS WON's Avatar
LS WON
yeap people can't believe that's the real temperature
To outside temperature
