Chrome Wheel Problem
Old Jul 11, 2010 | 10:53 AM
why1504's Avatar
why1504
St. Jude Donor '17
Default Chrome Wheel Problem
I have a 2009 Z06. I bought the car new about 6 months ago. I got back from a trip to the beach this week and went out this morning to wash the car. I am a soap only guy on wheels and have had good success with this. when I started this was what I found:
After I washed the wheel it hadn't come clean so I hit it with Tar Remover and then Goo Gone and still had this:
After inspecting all of the wheels the all have some of this on them but I started on the worst one (left front). It feels like I may have some etching here. I did not drive through any construction zone on the trip. What is my best alternative to fix this? Chrome Polish? A different chemical? Any suggestions are welcome.
Any Ideas what could have caused this?
(I also posted this in the care care section.)
Old Jul 11, 2010 | 11:10 AM
kevakasper's Avatar
kevakasper
2017 C4 of the Year Finalist
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Are these factory wheels, or were they chrome exchange or worse reproductions? The repros I had were so thin on the chrome, the barrels were peeling in no time. Looks like the salt attacked the chrome! If Factory I'd complain and try to get replaced.
Old Jul 11, 2010 | 11:13 AM
1FUNC5's Avatar
1FUNC5
try vinnegar and water 50/50 if that does not work go for either 3m swirl mark remover or chrome polish. that shoud do it
Old Jul 11, 2010 | 11:27 AM
why1504's Avatar
why1504
St. Jude Donor '17
Thanks!!
Old Jul 11, 2010 | 11:29 AM
hawkgfr's Avatar
hawkgfr
reason number one not to be a soap only guy...everything exposed needs layer of protection and even then there are no guarantees...
Old Jul 11, 2010 | 11:36 AM
surburban99's Avatar
surburban99
How about Simichrome polish? You could try on a small section to see if it works. Good luck
Old Jul 11, 2010 | 11:39 AM
1FUNC5's Avatar
1FUNC5
let us know how it turns out
Old Jul 11, 2010 | 11:47 AM
why1504's Avatar
why1504
St. Jude Donor '17
I will. Just got done with the body. BTW, I always put a coat of wax on the wheels too. Generally every other time I wash the wheels and always a coat of Zanio Quick Detailer. This is another reason this is so disturbing.
And they are factory wheels.
Old Jul 11, 2010 | 12:25 PM
why1504's Avatar
why1504
St. Jude Donor '17
Vinegar did nothing. So I moved to the Turtle Wax Chrome polish. Instantly I saw an improvement. I did the whole wheel. Here is the result:
However, on closer inspection I found this:
If you look closely, you can see the pinholes. I waxed the wheel and will get to the dealer later this week.
Crap.
Old Jul 11, 2010 | 12:30 PM
1FUNC5's Avatar
1FUNC5
that looks like sand blasting from the beach
Old Jul 11, 2010 | 12:31 PM
1FUNC5's Avatar
1FUNC5
was there alot of wind and was the car parked near the beach?
Old Jul 11, 2010 | 12:33 PM
1FUNC5's Avatar
1FUNC5
could just be pitting on thhe chrome in which case the dealer will have to replace
Old Jul 11, 2010 | 12:34 PM
lytmup's Avatar
lytmup
I'd go the warranty route if possible RIGHT NOW.
They are starting to pit and there is NO WAY to stop that.
Chrome done right should last forever.
ANY type of blemish in the prep layers before the chrome plating is added will cause pitting like this, and once it starts, there is absolutely nothing you can do to fix it. Nothing.
You can keep doing what you have done....and keep cleaning away that residue around the pinholes with an agressive cleaner/polish/compound......but those "pinholes" will only get bigger and bigger and there is nothing at all you can do to stop that.
Old Jul 11, 2010 | 12:43 PM
filmjay's Avatar
filmjay
St. Jude Donor '10
I'm starting to get the same thing on my wheels too. Just noticed it during the last wash a few days ago.
Wouldn't this be covered under the 6 years/100,000 miles Corrosion Protection?
http://www.chevrolet.com/owners/warranty/
Old Jul 11, 2010 | 01:05 PM
why1504's Avatar
why1504
St. Jude Donor '17
Well it wasn't very windy and it rained most days. I was surprised as the lack of salt on the glass and paint during the trip.
I am traveling this week and won't be able to get to the dealer before Friday.
I am very disappointed.
saplumr's Avatar
saplumr
No chrome can withstand salt.
Old Jul 11, 2010 | 01:25 PM
why1504's Avatar
why1504
St. Jude Donor '17
As an FYI, I washed and waxed before I left. It rained the first 5 days. I had the windows tinted on the sixth day. It rained on the 7th day. Sunshine on the 8th day ( I washed it then and noticed the wheels didn't come as clean as expected). Sunshine on the 9th day home on the 10.
Oh, and we had 4 other cars down there none of which experienced any ill effects.
To Chrome Wheel Problem
Old Jul 11, 2010 | 01:41 PM
lytmup's Avatar
lytmup
Nothing corrodes chrome.
What might appear to be corrosion is typically either:
- the chromium plating not being done properly during the electroplating process leaving "holes" in the plating allowing chemicals to start corroding the layers of metal that the chromium layer is on top of OR.....
- the underlying layers weren't prepared correctly and they start corroding from the inside.
You might want to try a basic google search of chromium and its properties in order to understand why the chrome itself doesn't corrode.
Old Jul 11, 2010 | 01:50 PM
saplumr's Avatar
saplumr
Really doesn't matter what the basics are I'm basing this on real world experience and we don't live in a perfect world.
Old Jul 11, 2010 | 01:59 PM
lytmup's Avatar
lytmup
Like i said, please educate yourself.
Saying salt corrodes chrome is just false. It has nothing to do with perfect world, its just facts.
