Windscreen Mesh vs Plexi?
Old Jul 18, 2010 | 06:43 PM
stevette17's Avatar
stevette17
Default Windscreen Mesh vs Plexi?
Any differences on using the Vettenet Plexiglas vs mesh GM windscreen , has anyone tried both?
Old Jul 18, 2010 | 11:55 PM
AvidFan's Avatar
AvidFan
I haven't tried both, but do have the plexiglass "vette net" windscreen. We saw the mesh windscreen at the Black Hills Classic and plan to swap. Here's why..
1. The mounts are permanent and much cleaner looking. You don't have to stop in the top lowering process to put in the mounts for the vette net, then finish closing the lid. After that, you have to make sure the vette net is not cocked when you try to slide it in the mounts or you have to wrestle with it to go completely down.
2. The mesh screen is taller, therefore the top rail does not obstruct any of your vision in the rear view mirror. The top rail of the vette net is all you can see across the middle of the rear view mirror.
3. Even though I have the storage bag for our plexiglass windscreen it's already scratched and we've only been using it a couple of months. I have never wiped it with a dry cloth, only with the same cleaner I use on the headlight lens covers and a microfiber cloth for glass.
Old Jul 19, 2010 | 12:25 AM
stevette17's Avatar
stevette17
so the GM one u just stall after the top is down? (do u really have to install the safety connector?)
To Windscreen Mesh vs Plexi?
