Exhaust rattle help
Old Jul 27, 2010 | 01:04 PM
WhatEverLolaWants's Avatar
WhatEverLolaWants
Active Streak: 90 Days
Default Exhaust rattle help
I have 2006 base coupe with stock mufllers. When I push up and down on the left muffler tips, there is a metallic banging sound. For the life of me, I can't see anything hitting. Everything is tight, all connections are in place. Every time I begin to move the car, I get a clank from that area, and again if I let up on the gas. sometime I get the clank for no obvious reason, probably a chasis change of some kind. Anyone experience this? any idea where its coming from. It is definately the muffler somehow. It is not the famous differential noise. thanks.
Old Jul 27, 2010 | 01:06 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
There is a hanger that goes up behind the rear fascia, I think it is a 10mm bolt that goes through a metal hanger. When it works loose it has that metal clanging. You will need to lay on your back and look up directly above the tips behind the rear bumper (fascia)
Old Jul 27, 2010 | 02:04 PM
WhatEverLolaWants
thanks for the reply. I'm not sure I see what you're talking about. Each muffler has a hanger welded to each side of the muffler at the back. Each hanger hooks into a rubber throuhg a hole in the rubber. Are talking about the bolt that holds the rubber on?
Old Jul 27, 2010 | 02:24 PM
mcandrew67's Avatar
mcandrew67
yes, if you lay on your back and look up, the two prongs from the muffler that hold it up at the rear. My bolt was loose and was making the clanging sound you mentioned. If you lay under and move each one see if that is where the noise is coming from.
Old Jul 27, 2010 | 02:47 PM
Racer86's Avatar
Racer86
Also look to the middle spring hangers in the tunnel area. 2 metal springs that have metal to metal contact at both ends. these guys made noise on our 08 coupe until I "corrected" the problem with stainless steel tie wraps, and added the necessary tension to them. Sounded like a tin can when releasing the clutch on slow starts.
Old Jul 27, 2010 | 02:49 PM
KWC6's Avatar
KWC6
My 08 is doing the same thing. Still under warrenty so I will have them fix it.
Old Jul 27, 2010 | 03:15 PM
WhatEverLolaWants
Its getting ready to rain. I'll put up on the lift tomorrow and see if either of these ideas work. Sounds like they're on the right track. Anxious to try it. Lousy rain. We've had 13" in 8 days .
Old Jul 30, 2010 | 06:34 PM
WhatEverLolaWants
Neither of these ideas worked. It is really strange. I move the left muffler left and when I move it back right I get a rather lous metal bang. But nothing is hitting, nothing is loose. It almost sounds like it is coming from inside the right muffler, but that doesn't make any sense either. Any more ideas?
Old Jul 30, 2010 | 06:38 PM
saplumr's Avatar
saplumr
I had this problem after I had a round of mods done a couple of years ago and like to never found it but there is was. When they connected the exhaust the drivers side spring was twisted and loose.
Old Jul 30, 2010 | 06:50 PM
WhatEverLolaWants
not the springs.
They look fine. and the clank is clearly coming from the area of the muffler itself. a real puzzler.
Old Jul 30, 2010 | 07:20 PM
dpigguy's Avatar
dpigguy
double check where the pipe goes up and over the rear end assembly. some have reported the same type noise as you and found it was the pipe hitting.
Old Jul 30, 2010 | 08:18 PM
LMB-C6's Avatar
LMB-C6
I'm just going to add some pics to show what everyone is talking about:
These are the springs at the midpipe, make sure they are still connected:
These are the hangers at the back of the muffler. Make sure the bolts are tight and that the muffler nubs are actually in the hangers.
Since you have stock mufflers it would be kind of strange for the 'over the axle' pipe to be hitting anything because it's 1 piece (unlike the one shown) but maybe a combination of a loose muffler clamp and loose hanger could cause it to shift...unlikely but....
make sure you have clearance in there:
Old Jul 30, 2010 | 10:23 PM
SilverScorp's Avatar
SilverScorp
Timely post. I'm having the same issue as the OP. Thanks for the pics LMB-C6, i'll look at those areas tomorrow morning. I have the Corsa Sports btw.
Old Jul 30, 2010 | 11:16 PM
KKMYC5's Avatar
KKMYC5
I had the same issue, did the same thing and it fixed the problem. I was told the new B&B exhaust that I added didnt have the same weight as the stock set, so the springs werre not pulled tight and rattled. Mine sounded like a set of keys rattling.
Old Sep 3, 2010 | 08:56 AM
Orangefanatic's Avatar
Orangefanatic
Default muffler popping sound
Had the exact same popping sound from the passenger rear muffler - nothing hitting, not a rattle sound but a popping when you physically move the muffler. I know it doesn't make sense but I put WD-40 over the muffler hangers and rubber connections and can no longer duplicate the popping sound.
Old Sep 3, 2010 | 12:42 PM
coolcat's Avatar
coolcat
My Chevy dealer fixed the clanging exhaust noise on my 08 coupe under warranty.
Old Sep 3, 2010 | 07:14 PM
pcguy2u's Avatar
pcguy2u
good for you, but what was the fix???
Old Sep 4, 2010 | 12:15 AM
zare191's Avatar
zare191
The noise you hear is just the car complaining about the excess weight of those big, ugly cans hanging under there.
Old Aug 7, 2014 | 08:51 PM
SoCalz51's Avatar
SoCalz51
7th Gear
I've got the same thing. Sounds like rattling keys around 2,800 RPM. Very annoying. I'm not clear on the stainless steel zip ties. What part is being tensioned?
To Exhaust rattle help
